Old 05-27-2015, 05:08 PM
emilano emilano is offline
Default Artist Control won't boot, stuck on "Avid" startup screen [SOLVED]
Does anyone know a way to trouble shoot this? I've tried repowering it a million times. The workstation shows up fine and attached in Eucon, but it doesn't see the surface and it remains stuck on the boot up "AVID" on the touch screen. Must be hardware related right? I've got Eucon 3.2.1 on an iMac 10.8.5 running PT 11.
Old 05-27-2015, 05:26 PM
Default
It turned out I needed to disconnect from my router and directly connect to my mac to get it to see the Artist control again. I had recently disconnected an Artist mix which had both units working fine with the router. For some reason I guess when you only have one connected you need to direct connect? Anyway, I post this for the poor sap who is having this problem in the future… cheers.
Artist control screen sensitivity garnoil Artist Series 0 02-05-2013 05:48 PM
Screen Life of the MC Artist Control V2 TechSpec Artist Series 1 05-11-2012 01:20 PM
Artist Control Screen Burn? hfth Artist Series 2 03-20-2012 05:20 PM
Artist Control V1 Touch Screen Xill Artist Series 3 08-19-2011 01:52 PM
