  #321
Old 04-21-2015, 08:49 AM
0level 0level is offline
Default Re: New Hackintosh / PT7 Sandy Bridge HD PCI Rig !!!
Wow nice score
wish you good luck with your build
  #322
Old 04-22-2015, 06:54 PM
venturajedie venturajedie is offline
Default Re: New Hackintosh / PT7 monster HD PCI Rig
Hello my friends !
my MAC G5 Is Dead
i need a recente hackintosh configuration
i have a protools HD But PCI Card not PCI-e
i have a SSL Duende /Hardware Firewire connection
and a UAD PCI Card
Interface Digidesign 96 I/O
can you help me people with a recente configuration Hackintosh ?
My problema its the Protools PCI card and SSL Firewire connection
What recente motherboard can i use ? and recente Processor ?
thanks to all !
  #323
Old 04-29-2015, 01:49 PM
temetrepo temetrepo is offline
My main mackintosh has ran flawlessly for the last few years so i'm selling my spare one on eBay. It never got used so i'm letting it go. It's got 10.9.5 installed.
Jetway board based. Can run up to an HD4.
http://www.ebay.com/itm/281677632601...84.m1558.l2649
Throw me an offer.
-J
Originally Posted by JustinA
"Soon" as in we should be refreshing our browsers, or "soon" as in ADC coming to LE?
  #324
Old 04-29-2015, 05:54 PM
CME CME is offline
How many PCI slots do you need?
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
  #325
Old 05-01-2015, 04:03 PM
2 PCI Slots
One for Digidesign Card PCIX ( PCI ) Protools HD Card TDM
and other to Universal Audio Card ( PCI )
Thanks !
  #326
Old 05-01-2015, 04:14 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by venturajedie View Post
2 PCI Slots
Thanks !
No way, those TDM cards are like the potato chips, you can't have just one....you honestly need an HD3 system to do any real work....
ie- real work meaning tracking a band
Daniel
  #327
Old 05-18-2015, 04:37 PM
courpignac courpignac is offline
Default
Originally Posted by Dimak415 View Post
Guys,
I have to tell you. The JNAF93 was one of the easiest builds I've ever done.
Make sure to use an Ivy Bridge processor like a 3770 (no K series required since you can't overclock with the Q77).
You'll need Mavericks 10.9.3 or 10.9.4.
Unibeast (check out tonymacx86)
What works:
No DSDT needed for UEFI (though I may patch one later)
Install went great. Just wait for the white screen to go into install. Took 5 min.
DVI works (HDMI untested) HD4000 video works OTB
Both LAN ports work
Looks like the slow iLok problem is solved with no LAN Kexts or futzing
32 Gigs of RAM @ 1600mhz using XMP Profile
All Intel 7 series Storage SATA ports are visible
Let me know if you have questions.
hi Dimak
is it better to get a IE 3770 or a IE 3770 K with the jetway JNAF93 board?
thanks
  #328
Old 06-18-2015, 09:44 AM
Sugarnutz Sugarnutz is offline
Originally Posted by courpignac View Post
hi Dimak
thanks
A little late on the reply, but since you can't overclock the Jetway a 3770 (Non K) would be fine.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
  #329
Old 05-12-2016, 08:11 AM
MSB Mastering MSB Mastering is offline
I'm still running this! I've alternated between an HD2 with an RME 9632 and running it as an HD1 with an RME 9632 AND an RME 9652. I've got two spare motherboards which I'm holding on to. I'm now on W10 and am just about to upgrade to Samplitude ProX2 and possibly make it an i7. I might also get an Avid Omni which would get me HEAT as well.
This is by far the best computer I've ever owned, and since I've got it in about 30 stages of cloning with Acronis, it should live forever! If you just want it for ProTools, I think it will run as an HD3. i7+HD3 accel should be plenty powerful for most people.
  #330
Old 05-12-2016, 08:23 AM
jeremyroberts jeremyroberts is offline
Me too. 4 years of daily pounding. Upgraded PT a while back to 10.3.8 - but didn't touch the OS stuck at 10.7.4
This machine is a beast for protools.
Not good for anything else (nor do i want it to be).
--Jeremy
Hackintosh for Pro Tools 7 - 7.4 anybody ? zavid Pro Tools TDM Systems (Mac) 0 02-19-2014 03:51 PM
Hackintosh Problem pocketcalc macOS 2 07-08-2012 05:35 PM
Hackintosh with PT9 HD Native? PMedia macOS 9 07-11-2011 09:12 AM
Hackintosh on my rig? Raoul23 Pro Tools TDM Systems (Win) 7 07-01-2011 03:26 PM
Hackintosh Help HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-16-2010 10:45 AM
