2019.5 Hardware inserts cause huge delays
When I say huge delays I don't mean latency, I mean everything grinds to a halt for 3-4 seconds and I can't do anything.
This happens mostly when I do things on an insert like add a new plugin, close a plugin, remove a plugin. If I load a new plugin everything completely freezes for 3-4 seconds. If I remove all hardware inserts everything is fine. It also doesn't matter which track I'm on, if there's a hardware insert in the session it happens. |
Re: 2019.5 Hardware inserts cause huge delays
Tough to comment with zero info on anything. I would uninstall and go back to the last version that worked well
Let's start with the basics: what is your audio interface?
HD Native card
HD OMNI interface OS: Microsoft Windows 10 Pro OS Version: 10.0.17134 Build 17134 Mainboard: Gigabyte Z370 HD3 Processor: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz, 3696 Mhz, 6 Core(s), 12 Logical Processor(s) RAM: 64 GB (4 x 16GB) PC4-19200 2400MHz DDR4 RAM GPU: NVIDIA GeForce GTX 1070 Ti |
Update. It's a problem with delay compensation. If I turn off delay compensation then the problem stops.
With delay compensation on it only happens if there is a hardware insert on one of the tracks. If I remove all the hardware inserts then the problem is gone. |
No problem here using several hardware inserts.
Protools HDX(x3) High Sierra, cheese grater mac pro, magma expansion chasis and 6 i/o interfaces. Sent from my iPhone using Tapatalk |
Sent from my SM-G975U using Tapatalk |
Low latency monitoring with HW inserts still broken in 2019.5 | XJENSEN | Pro Tools 2019 | 0 | 05-09-2019 12:03 PM |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
Hardware Inserts | CosmicJunkie | Pro Tools TDM Systems (Mac) | 1 | 11-20-2007 03:12 AM |
Hardware delays for vocals | MidnightFlyer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-04-2005 09:42 PM |
huge delays when I press 'record' | Faulty Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-27-2003 07:18 AM |
