"Pro Tools is unable to communicate with HUI"
Hi
I've just got started with Pro Tools 11 and I'm trying to hook up my Akai MPK Mini to a session but I keep getting the "Pro Tools is unable to communicate with HUI" error every time I try and use it. I've tried setting it up through the MIDI Studio and Peripherals settings but I'm still getting no luck, the same error occurs when I try and use MIDI from my Yamaha digital piano through my Saffire LE interface. Both work fine in all my other programs. Any ideas? |
Re: "Pro Tools is unable to communicate with HUI"
Hi Luke,
I have a Behringer BCF2000 controller. The computer is HP 64bit win8.1 This controller works well with Vegas and Sound Forge ( this means that the drivers are properly installed and the system recognizes pretty good). When I select on PT ( Configuration> PERIPHERAL > Controllers) HUI > BFC2000 - (emulated), then.... same as you: A popup window saying that PT can not communicate with HUI. If you have any solution , I'd appreciate your help. My SANDRA REPORT HP h9-1304es 103C_53316J G=D Microsoft Windows 8.1 A Casa 6.03.9600 x64 Tarjeta principal : Pegatron 2AD5 BIOS del sistema : AMI (OEM) 8.17 02/06/2013 Memoria total : 16GB DIMM DDR3 Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (4C 8T 3.89GHz, 3.9GHz IMC, 4x 256kB L2, 8MB L3) Conector/Ranura : FC LGA1155 HP Core (Ivy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.6GHz 128-bit Módulo de memoria 4X : Micron 8JTF51264AZ-1G6E1 4GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6) NVIDIA GeForce GTX 680 (8CU 1536SP SM5.0 1GHz/1.2GHz, 512kB L2, 2GB 6GHz 256-bit, PCIe 3.00 x16) SAMSUNG MZ7PC128HAFU-000H1 (128GB, SATA600, 2.5", SSD) : 119GB (C:) (D:) Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm) : 2TB BD-RE BH40L (SATA150, BD-RE, DVD+-RW, CD-RW) HP LaserJet 100 color MFP M175 PCL6 (600x600, Rendimiento de color) Hewlett-Packard HP LJ100 M175 Scan (Digitalizador (Escáner), USB) Gigabit Ethernet Qualcomm Atheros AR8161 PCI-E (NDIS 6.30) (Ethernet, 100Mbps)
Thanks Splitman |
These threads are a joke. Never get any answers. I posted one a month ago and got not a single response. Spent hundreds on software that I can't even use.
No idea why you are posting on this old thread from 2014 about HUI. Edit: Oops Pro Tools First does support HUI.. it does not support EUCON. Last edited by Darryl Ramm; 07-05-2020 at 03:58 PM. |
From what I find on youtube, the Akai Mini does not use HUI at all, so I don't know why you would try to enable HUI. Some people are just not cut out to be engineers. That doesn't take anything away from anybody's musical talent. The key is to recognize your strengths, and to recognize where your weaknesses are, so you can either learn and overcome, or delegate to others when you need to
"These threads are a joke. Never get any answers. I posted one a month ago and got not a single response. Spent hundreds on software that I can't even use."
Well if you bothered to check your post you would see that there are replies.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Dave - this is a thread from 2014 I expect the OP no longer cares.
Not sure why hugolamb7 is complaining on this thread. Or if it has anything to do with HUI or anything else here. |
Oh yeah, I saw. And I also expect that kind of response from someone with little to no experience with PT. We users need to be smarter than the gear we buy
GETTING ERROR "Pro Tools cannot communicate with 003" WHAT IS GOING ON!?!?!? | The Zone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 09-13-2010 03:04 AM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
01v96 "unable to communicate w/HUI" i7 | alanbtaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-21-2010 02:55 PM |
"Unable to Communicate" fix? | Serge Perron | ProControl, Control|24, Command|8 | 0 | 11-06-2009 03:16 PM |
"ProTools is unable to communicate with Motormix" | ISedlacek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-05-2003 12:21 AM |
