play dv movie out firewire port
hi..
i´m looking for some help. i´m doing some sound arrangements for a movie and i would like to be able to see it in a video monitor. i think i am doing everything ok. but the " play dv movie out firewire port " in the menu is not lit. this is my connection : computer - firewire port out - firewire port in media converter - video monitor can someone give some help please..... thankz |
Re: play dv movie out firewire port
What kind of video converter are you using? You are set up correctly, so the only reason why I can think of that the "play dv movie out firewire port" is greyed out is if it is not a dv. If you import a quicktime movie, without converting it to dv, it will not work. If this is the problem, use quicktime to export the movie to dv (this may only be available in quicktime pro).
Hope that helps. |
thanks a lot . i will try it that way . i´m shure it will work
Play DV Movie Out Firewire Port | XYZ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-05-2005 04:12 PM |
play dv movie out firewire port | jay dust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 05-07-2005 10:27 AM |
play dv movie out firewire port? | jay dust | Post - Surround - Video | 4 | 05-03-2005 07:58 AM |
DV Movie won't play out of FireWire Port | Dobbs | Post - Surround - Video | 5 | 04-27-2005 03:13 AM |
play DV movie out firewire port | jnamm | Post - Surround - Video | 6 | 09-03-2004 12:40 PM |
