  #41
Old 10-01-2019, 02:54 PM
Default Re: Plugins not scanning nicely
Originally Posted by DaveUK View Post
Any benefits of 10.13 over 10.14 or vice versa as far as protools etc is concerned?
Depends on the PT software version you are using, and whether your hardware uses SSD drives (or you are planning to).
PT2019 works very well on Mojave. APFS was introduced in HS and developed further on Mojave. I've heard Catalina brings proper Snapshots easily available for end users. But you shouldn't update your spinners' filesystems because APFS is designed for SSD technology.
  #42
Old 10-01-2019, 03:37 PM
DaveUK DaveUK is offline
Oh yes I forgot about the new file system - do I have to use that?
iLok support have echoed Izotope's comments. They say it is a known issue which they are working on with Avid, and they currently recommend either restoring to an earlier backup or upgrading to 'the next version of MacOS'
  #43
Old 10-01-2019, 03:46 PM
No, but if you have SSD's you would likely want to
  #44
Old 10-01-2019, 03:47 PM
Neale Neale is offline
iLok. That’s fun. So at least it wasn’t me.
Let’s see what happens, maybe I wait it out.
  #45
Old 10-01-2019, 03:52 PM
So is it an Apple issue that has affected iLok that makes some auths fail? Or is it an iLok issue that they need Avid input to fix it and just happened to surface after some Apple update and only make some license auths fail? I'm confused
  #46
Old 10-01-2019, 04:27 PM
I believe the iLok issue is a different issue to the Ozone issue, but they are both believe to have been caused by the same apple update. I was just lucky to get both I guess! ITy's been a very dispiriting couple of days.
  #47
Old 10-01-2019, 04:42 PM
I’m seeing the 64-bit warning with some Plugin Alliance plugins, JUST my Lindells... and they’re machine-authorized, not iLok... but maybe that conflict comes from the Pace system not playing nicely with that supplemental update?
  #48
Old 10-01-2019, 04:52 PM
That sounds reasonable, lets wait and see who figures this out and when
  #49
Old 10-02-2019, 03:29 PM
Went for the possibly rash decision to upgrade to Mojave. After a while getting that all configured and various things updated - ProTools, Ozone, various other plugins and licences all appear to be back working again!
  #50
Old 10-02-2019, 03:34 PM
Good to hear!
scanning plugins bongo_x Pro Tools 10 1 03-29-2016 08:50 PM
ProTools scanning plugins on every launch? TimNielsen Pro Tools 12 2 02-20-2016 08:50 AM
First does quit on launch when plugins scanning clausiii Pro Tools | First Discussion 9 09-19-2015 02:48 AM
10.3.10 ran out of memory scanning plugins crizdee Pro Tools 10 29 02-08-2015 12:24 PM
Live Lite 7 for Digi not re-scanning plugins Gothboy Virtual Instruments 0 09-21-2009 10:10 AM
