#21
#22
Re: Measuring Latency & Scarlett 6i6 Beta Results
Then why do a round and around again trip latency test?
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#23
If everything works properly, the first loop should show no latency because of PT's "Playback Engine" latency compensation - which apparently can't be turned off. If that's the case, the second loop shows the (RTL) latency directly. Otherwise it needs to be adjusted to reflect the error in PT's compensation. Thanks for asking !
#24
I think mesaone did an irrational "OT" on this issue. You might want to see http://duc.avid.com/showpost.php?p=2266607&postcount=25 if you haven't already.
#25
Come on, man.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#26
I'm worried about you, are you going to be OK?
#27
Don't be worried. It was just a typo, happens to everyone.
#28
Just leave it alone it's not worth the brain power, I thought mesa had a great response....... He did a double round trip test but just wanted to measure a single trip...... It's best left alone Cheers
#29
I did these tests for years and I assure you only the single loop is necessary to obtain your results.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
#30
Consistent with Darryl Ramm’s assertions (http://duc.avid.com/showpost.php?p=2260348&postcount=26), I was unable to disable I/O latency compensation on any channel (all of which indicated 0 delay) either individually or via the "Delay Compensation" (ADC) control. Maybe your tests were with an older/different version of PT (I’m using standard PT12 with a PC). Can you post some of your test results?
DigiGrid IOS 8IO+ DSP | simon.a.billington | AAX Plug-ins | 0 | 12-04-2014 07:10 PM |
Measuring Analog Distortion? | SuperReverb | Pro Tools TDM Systems (Mac) | 2 | 10-18-2010 07:02 AM |
Correctly measuring input db | PTGuy | Pro Tools TDM Systems (Mac) | 4 | 05-12-2006 12:36 AM |
Measuring Midi Latency | JPS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 07-01-2002 10:24 PM |
Measuring the latency (experiments) | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-16-2000 10:15 PM |
