Old 09-14-2004, 09:49 AM
MWOOD MWOOD is offline
Default Still cant get wavedriver 6.4
I hope that someone can help,
I have been following the threads, trying what I can from them and I am unable to even find wavedriver 6.4.
The setup file does not appear on my 6.4 disk and the .exe does not show on my system when I reload PT. I have been at this all night.
Should I see the wavedriver in my program list on XP (SP1). Should I have access to the driver setup on my installation disk (V 6.4).
Thanking anyone who can help in advance
// I dont know what it is - and I'm too afraid to lick it \\
Old 09-14-2004, 10:02 AM
spkguitar's Avatar
Default Re: Still cant get wavedriver 6.4
Check out Appendix c of your Getting Started guide
The WaveDriver is installed by default when you install Pro Tools.
There is also information there about configuring it for use with your system.
Old 09-14-2004, 10:07 AM
I have gone through the process as thoroughly as I can.
Where it mentions wavedriver in the currently installed programs list I draw a blank. It appears not to have been installed. I have removed and reinstalled PT a number of times with the same result.
Old 09-14-2004, 10:35 AM
spkguitar's Avatar
It mentions the Currently installed programs list in the "Removing the Wavedriver" instructions.
You're not trying to remove the wavedriver, are you?
I'm kind of confused here, as you said you are trying to access the .exe file, and it doesn't quite work that way.
Have you read the section on page 116 called "Configuring WaveDriver for Windows Media Player and Other Third-Party WaveDriver Programs"? That is the information I think you are looking for.
What exactly are you trying to use the wavedriver for? It might help to know that, as well as all of the details about your system.
Old 09-14-2004, 05:29 PM
What I want to use is Windows Media Player.
The problem is...
.... the digi card wont show up in audio properties in windows (as the default audio unit).. Which means you cant use it with anything that requires its audio to go through WMA.
From the documents it suggests that the wavedriver is a separate .exe file. I am unable to locate this file (just to know that installation has occured). I have followed all of the threads that I could find on this site and have tried as many of the relevant fixes that I can. Still nothing.
- MB. ASUS A7N266-E , CPU. AMD Athalon 1700+ -
I hope this provides more info
Old 09-14-2004, 05:50 PM
Download and run MME Helper from the WaveDriver 6.1.1 download page and list the programs in the MME Helper listbox.
As always, I suggest you first uninstall all aspects of Pro Tools using the Add & Remove Programs control panel.. search for the file dalwdm.sys and delete all occurences of the file (you should find 2 copies).. reboot and reinstall Pro Tools 6.4 and then reboot and then install the WaveDriver 6.1.1
Go to Start->Settings->Control Panel->Sounds and Audio Devices and the Audio tab.. tell us if your Digidesign hardware is listed in the Sound Playback default devices list.
If it's not, then tell us exactly which other devices you have hooked up and installed in your PC including all FireWire devices.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
wavedriver help 001 XP AMZavareei 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-29-2005 12:55 AM
wavedriver Mariner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-15-2004 09:19 AM
Wavedriver.... Mike Teezie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-24-2002 11:55 AM
what does the wavedriver do exactly. gregoryb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-13-2002 12:39 AM
PT|24 / NT - Why is there no wavedriver ????? Echo studios Pro Tools TDM Systems (Win) 10 10-30-1998 06:17 AM
