Old 05-08-2020, 05:35 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Reason Rack AAX -
I just watched a video at Groove 3 on Reason 11 and the Rack with Paul Ortiz. Apparently there is currently NO MIDI out feature for the players in the rack... or at least there wasn't with 11.1. Don't know if that's changed yet or not.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 05-08-2020, 05:44 AM
Sardi Sardi is offline
Default Reason Rack AAX -
No there definitely is. It was added in 11.2 which is what that video I linked is showing.
I can get MIDI to pass, but not the arpeggios or chords. It just passes the single note input.
As I said, I could have sworn I did this with Cthulhu and if you agree that I’m not imaging that, then it leads me to believe that in theory it should be possible. So, if it’s not a PT limitation, then it’s a Reason limitation or user error.
I’m scratching my head to work out why they don’t just do the copy to track workflow with the players - the same way they do it within Reason itself. Another limitation of working in a DAW? You can drag the MIDI from a REX player or ReDrum in PT, so you’d think dragging or copying from a player would also be possible.
Confusing...
Old 05-08-2020, 06:10 AM
K Roche's Avatar
K Roche K Roche is online now
Originally Posted by JFreak View Post
Whoa, that doesn't sound good. Mac users having same experience?
I would be curious about that also. I was thinking about downloading, but I am not all that tech savvy and hate to be a beta tester
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 05-08-2020, 06:55 AM
I’m a Mac user. I haven’t experienced any of the issues that Donald did in terms of system usage.
Im still running the demo atm, so can’t comment on authorisation issues. Works fine in demo mode.
Old 05-08-2020, 11:08 AM
DonaldM's Avatar
Confusing...
Here's a headscratcher for you, Sardi. So, I set up Reason Rack on Inst track 1 and put another VI on Inst track 2 (Dune 3 in this case). I placed a simple 8 measure chord progression on the Reason track. In the rack I installed the Dual Arp, which also installed the MIDI Out module right below it. It was set to Ch 1. On Inst track 2 I changed the instrument input (not the track input) to Reason Rack plugin MIDI ch 1. Then hit play and the chord progression on the Reason track played the Dual arp, which, in turn, played the VI on track two as expected. I was even able to record the MIDI output from the Dual Arp playing on track 1 to track 2.
So then, I took the Dual Arp off the rack, and replaced it with the Scales and Chords plugin. I record armed the Reason track, and began playing notes. I can see that Reason see the MIDI input, but NOTHING plays on the VI on track 2 even though I have the input set correctly from Reason on Track 1 as before with Dual Arp.
So, Dual Arp plays the 2nd VI on a different track, but NOT Scales and Chords.
One could go bald on such issues!
  #16
Old 05-08-2020, 11:34 AM
That is the EXACT workflow I tried, but all I get is the single notes passing to the VI, not the arpeggios or chords. I can even record the MIDI to the secondary instrument track and it’s just the single notes.
I’m going to play around with it some more tomorrow, but if you’re saying you got it to record the arpeggios to the secondary MIDI track, then it must be possible. Would validate our recollection of Cthulhu.
  #17
Old 05-08-2020, 11:52 AM
DonaldM's Avatar
Confusing...
  #18
Old 05-08-2020, 11:58 AM
DonaldM's Avatar
Please ignore my duplicate message...clicked too fast on something!
Anyway, Yes, the Dual Arp played just fine as described above. And the entire chord played, not just one note.
But I can't do a thing with the other one "Chords and Scales".
Also, I can't seem to do anything with NOte Echo either. I set it up a VI on an instrument track, then added the rack on the same track right below the VI and put Note Echo in the rack. I can see the audio signal hit the rack, but NOte Echo does nothing. It does however if I place a VI on the rack with it. So, apparently you can't process audio with it like an effect insert.
  #19
Old 05-08-2020, 05:29 PM
Did the demo wipe out any previous install you had of Reason? I have R 8.3
Jack
QAPLA!
  #20
Old 05-08-2020, 05:57 PM
No.
I just renamed my Reason 10 app like I do with PT when testing new versions.
PT9, Reason 2.0 and Digi 002 Rack silvermohawk macOS 4 08-23-2011 06:13 AM
003 Rack and Reason Issues? micline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-23-2010 06:49 AM
help with 002 rack and reason midi spider00rr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-30-2006 08:29 AM
002 Rack & Reason Problems taekniq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-24-2005 10:56 AM
REASON AND DIGI 002 RACK Rail Jon Rogut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 07-21-2003 05:58 PM
