S1 delay in sensing fader touch after starting playback
Brand new S1 with firmware updated. I am doing Volume automation in Touch mode and am stopping and starting regularly to redo sections. However as soon as I press play and put my finger on the fader it takes about two seconds before registering that I'm touching it, almost like it's in Preroll (which it isn't.) If I continue playing and release and touch it senses straightaway, but for some reason struggles to do so without exception every time I have just started playback. I also have Eucon connectivity issues in that manual says to start up S1 before starting Mac, but time and again Eucon doesn't sense S1, restart Eucon Applications no good either, the only thing that seems to work is to shut off S1 and back on while Eucon software is running. Thanks Mac Pro 2009 Sierra 10.12.6 Pro Tools Ultimate 2018.10.0 Mac Pro (early 2009) 2 x 3.46 GHz 6-core Intel Xeon 32GB 1333 MHz DDR3 ATI Radeon HD 5770 1024MB
2.93 GHz Intel Core 2 Duo 17" Macbook Pro 4GB 1067 MHz DDR3 Mac OS 10.6.4 Pro Tools 9.0.0 Mbox 3 MC Mix Siig Firewire 2-port Expresscard Genelec 8020B speakers Last edited by Ruthven; 03-31-2020 at 09:32 AM. |
Re: S1 delay in sensing fader touch after starting playback
Couple of things, Try the automation writing before ever opening EuControl Window and see if its instant. Then open EuControl (specifically the softkey window) and see if it slows. The way to get out of this is to restart EuControl and not open it.
For 20.4 we have improved the above and also the startup of S1. I think the guide is wrong saying turn the S1 on first, it can get an IP address early and it might not be the correct one. I would startup the Mac/PC first and EuControl. |
Touch fader to focus | PTPerson | ICON & C|24 | 9 | 05-16-2019 09:25 PM |
Using touch-fader for other apps? | Sir Hannes | Avid S1, S3, Dock and Control App | 1 | 08-01-2017 11:00 AM |
Shift+fader touch= wtf!?!?! | C52382P | Artist Series | 3 | 04-23-2015 02:51 AM |
C24 fader touch issues | ziggy2282 | ICON & C|24 | 9 | 02-15-2012 11:22 AM |
touch status of fader after playback has been stopped | Felix Rost | ICON & C|24 | 0 | 01-06-2008 01:15 PM |
