Mono mult output bug in PT 12.8?
I have a mono track for 2-pop and tones that uses multiple output assignments to put tones and 2-pop directly on the re-record tracks. But for some reason, I can't mult to more than (10) outputs!. This is serious. That track usually goes to 40-50 outputs. Anyone else seeing this?
My other multiple output assignments seem to be behaving, but maybe that's because they're all assigned to fewer than (10) outputs. Wasn't seeing this in 12.7.x.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
That is a reported bug issue on 12.8. In my case I cannot use the alt shift output to change the output channels on big sessions without an error.
Re: Mono mult output bug in PT 12.8?
Thanks for the confirmation. Just to get Avid's attention even more:
http://protools.ideascale.com/a/idea-v2/277358 I tested in a new session. Anything above (10) mults is dropped after you save, close and re-open.
Ouch
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Hey Avid! This was the only bug in 12.8. Not fixed in 12.8.1.
That said, 12.8 stability was extraordinary, but please, fix the mult bug.
Same here. This is a real drag.
Only work around that I can find at the moment is to import the pop/tones track from a session that was not saved in 12.8. Do this just before making stems. However once you close and re open the session, you're back to square one. Last edited by laki; 09-04-2017 at 11:43 PM. Reason: Added something constructive rather than just complaining. |
Hi Guys,
I've got a workaround for this... You can also assign outputs for your tones via a send. You can control select multiple outs on a send. You have the same limitation on how many "mults" you can have per send (16 discreet?) before they drop off. Just make another send and continue on. Let's hope they fix this! |
I use the same workflow, but 50 outputs??
Eeek! Multiple channels or Roll back! |
Mult-mono vs Stereo Plugins | JLEpperson | Tips & Tricks | 4 | 08-10-2010 05:48 PM |
Best way to mult master output 1-2 to 3-4 | vudoo | Pro Tools TDM Systems (Mac) | 4 | 11-26-2008 09:41 PM |
PC Output in Mono? | stuart97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 09-03-2008 08:19 AM |
MBOX 1 mono output? | megahurt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-21-2007 09:35 AM |
When you output a stereo aux track to a mono output? | el biciclista | Pro Tools TDM Systems (Mac) | 5 | 06-04-2003 12:10 AM |
