Old 03-26-2018, 03:11 PM
pmueller pmueller is offline
Default Profile FOH Midi Issue
Hi
Our basic start show file has 2 basic snapshots programmed, each with a different midi message program change, to recall 2 different madi router presets.
Works fine.
Issue I get:
If I add a new snapshot, DUP ore NEW, and RECALL it (midi message indicator and MIDI scope both unselected) it still shoots out one of this program changes.
There is no program change visible in the snapshot midi list.
Is it a bug?
Any idea is much appreciated. Thanks.
Patrick
www.tonkultur.ch - remote recording services
Old 03-27-2018, 06:12 AM
Valentyn Valentyn is offline
Default Re: Profile FOH Midi Issue
If you have Options->Snapshots->"Snapshots Send on Channel" enabled and set, then recalling a snapshot will send a ControlChange+ProgramChange pair of commands, where:
- bank is snapshot index divided by 128
- program is a remainder after division of snapshot index to 128
Snapshot index is zero-based, i.e. snapshot number 1 has zero-based index 0, snapshot number 2 has zero-based index 1, and so on.
For example, recalling snapshot 150 (number as shown in Snapshots page) will send 2 MIDI commands:
- Control change with bank 1 (149 / 128 = 1.640625, truncated to 1)
- Program change with program 21 (149 mod 128 = 21)
I.e. snapshot number = Bank index * 128 + program index + 1.
See "Triggering of External Devices on Snapshot Recall" in VENUE guide for a better explanation.
Old 03-27-2018, 08:43 AM
Hey Valentyn
Perfect working answer, THANKS 1000....
I didn't fully understood "Options->Snapshots->"Snapshots Send on Channel" enabled" function.
Unselected and see it works perfect.
Thanks again!
Patrick
Profile / Pro Tools 8 HD / Virtual Soundcheck issue klyphskinner VENUE Live Sound Systems 5 12-03-2016 01:16 AM
D-Show Profile Headphone output Issue gagaiop VENUE Live Sound Systems 1 10-12-2010 08:02 AM
Using Midi with D-show Profile Rob Warren VENUE Live Sound Systems 3 10-09-2009 07:55 PM
Midi and Venue Profile jxgriffi MIDI 3 03-02-2008 03:31 PM
Need P&G MM-16 MIDI Profile for Yamaha 02r control Mark Severns MIDI 1 10-31-2005 12:09 PM
