Old 07-19-2000, 08:15 PM
F. Molina F. Molina is offline
Default MIDI still burst in Logic 4.5!
Dear coleagues,
i'm using Mac with Digidesign hardware and Emagic software from 1995 with no any real problem, but now i'm really losing my sanity trying to solve the MIDI hanging notes and burst of the LAM/001 combo.
I don't know what to do just now. I got five months ago a G4/400 AGP and haven't got a moment of pleasure due to the midi problems.
I have problems trying to access with the built in MIDI interface and with the MIDISPORT 2X2 too. So problems persist using OMS.
I've found a better MIDI performance when no any recording or playing audio tracks are running. But the most important bursts happen when i try to access VST instruments. I don't get no more than two or three minutes without a terrible burst working with LM•4 or Pro5. All the MIDI mess i got is when MIDI-in is working.
So for what do i have to wait at this point?
a) A new MacOS with better usb support, among other things? or
b) a new DigiSystem INIT? or
c) a new Logic Audio Version?
Thanks in advance for any response.
Old 07-19-2000, 08:34 PM
Kickin.da.speaker Kickin.da.speaker is offline
Default Re: MIDI still burst in Logic 4.5!
From another thread:
DigiTechSupt
posted July 18, 2000 10:10 PM *** * ** **
I have been working with engineering to help narrrow down the problem with MIDI input through the Digi001 with Logic. No fix is available yet, but we are much closer to a resolution.I'll keep everyone posted.
Brent.
David.
6am eternal
Old 07-24-2000, 08:45 PM
ThomCat ThomCat is offline
If you have a MIDI interface you shouldn't need to even cable MIDI to the 001, which should solve the problem. Is the MidiSport an interface? Search the DUC for the threads...I think it may have to do with how you handle the 001 in Logic's environment. I never even let Logic know I had an 001 within the environment, I only changed drivers. I use a MOTU Timepiece II and have never had a MIDI problem with Logic/001, so there is hope.
Also, the Unitor/Logic combination is technically the tightest MIDI combination available due to active MIDI transfer. Check it out at www.emagic.de.
If you are using 5 year old software you might be surprised at how much better Logic is by now. Using software that old is a little like using a typewriter to access the internet. Version 3.5 from just 2 years ago is a dinosaur by comparison to v4.x. You owe it to yourself to scrape up the $200 for v4.5. The plug-ins alone are worth it. Good luck.
96 io burst of noise pie55 Pro Tools TDM Systems (Win) 4 08-21-2011 01:46 PM
White Burst eight16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 07-31-2010 02:23 PM
Logic Pro users: Midi & audio between Logic & PT dtmprod Pro Tools TDM Systems (Mac) 4 09-24-2006 04:16 PM
burst of static--help! patchboy Pro Tools TDM Systems (Mac) 10 09-21-2001 06:04 AM
Hello Logic users.......Please explain about Logic Midi elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2001 12:35 AM
