Old 12-28-2013, 09:13 AM
jvining jvining is offline
Default Required software for Eleven Rack
Hi all -
I'm purchasing a used Eleven Rack that does not include PT, but does have the expansion pack preinstalled.
What software would be required to be able to edit rigs on my computer? What's the oldest version of ProTools I can acquire that would be compatible, and are there any plugins that need to be purchased?
Since I am a longtime Logic user, My plan is to set up an older, unused macbook just to run PT and edit rigs. I'm just not sure EXACTLY what I need to do it.
Thanks!
Old 12-28-2013, 09:27 AM
Default Re: Required software for Eleven Rack
Originally Posted by jvining View Post
Hi all -
Thanks!
Currently you need a version of Pro Tools 8 LE, 9 or 10 to edit using the GUI. That might change in future if Avid does a stand alone editor... but don't hold your breath. If you don't also want to use Pro Tools then just live with using the Eleven Rack front panel, its very easy to use. And the Eleven Rack works fine as an interface in Logic Pro without any of this being needed.
Old 12-28-2013, 09:51 AM
Right, So is there a plugin I also need to get as well for Pro Tools?
Old 12-28-2013, 09:58 AM
christophersad christophersad is offline
you can get an 8le copy for under $50 on ebay,but if what you need is just uploading/downloading presets (wich u can find plenty at elevenrackpresets.com forum or on Benoni's blog) then u can google for elevenhack wich is an usermade program that let you download/upload presets. welcome to the orange side :)
Old 12-28-2013, 10:04 AM
Why would you go through the PITA of setting up Pro Tools just to edit rigs. The only Pro Tools you can buy from Avid now is Pro Tools 11, it comes with 10 that has the GUI pre-built in and will cost you around $600 to $700. If you find an old Pro Tools 8 LE version for sale you will need to add the GUI plugins.
Ok - Thats good to know. Maybe I won't need to deal with PT after all.
But if I go the PT8 route - then no other software is needed?
Just PT8 and the Eleven Rack drivers from Avid and that's all I need?
Old 12-28-2013, 10:09 AM
If I can do it with PTLE8 then it's worth it.
If I have to use 10/11 then it's not.
I just watched a video on youtube of some guy that had it running on PT8 with no problem - all he did was install the latest driver. So I guess that is actually all that is needed.
Old 12-28-2013, 10:53 AM
Is the OS you want to run on compatible with Pro Tools 8 LE?
There is a fair amount of dicking around involved here for little benefit. Just get started and learn how to use the Eleven Rack front panel.
Old 12-28-2013, 10:57 AM
Funny, I was just reading that 8 won't run on any OSs that I currently run.
This is definitely starting to sound not worth it. Looks like standalone and ElevenHack are the way to go.
Old 12-28-2013, 12:34 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
And these operating systems are...???
Bruce Paine
System Details
Eleven Rack Firmware/Software Question bradley.jacobsen Eleven Rack 6 01-24-2014 12:00 AM
Can I sell Pro Tools 9+10 software that came bundled with Eleven Rack? krubel54 Eleven Rack 4 06-25-2012 06:16 AM
Can eleven rack GUI/Software be used out of PRo tools? trock Eleven Rack 7 10-02-2011 09:53 AM
Pro tools LE plus Eleven Rack. Audio Interface required? needled39 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-15-2010 05:27 PM
Is this possible with Eleven Rack? Recording technique help required... rmpacheco Eleven Rack 13 10-13-2010 11:33 AM
