Re: Offline bounce bug ?
Automation ? Specifically volume automation ?
Don't have the time to update now but I'm also interested to see if the problems is still there in the new version.
Can you keep us updated please ? Thanks Pascal
Pascal Zander Stand up Audio recording & post www.standup.be MacPro 2019 16 Core 10.15.7 PT Ultimate 2021.3.1 HDX 1 D-Command |
I just wanted to do my very first offline bounce @24bit wav and bang - PT11.0.2 crashed. Online bounces worked so far.
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Anybody figure this out? This happens to me on every offline bounce as well.
Not good. Offline bounce was one of the main reasons I upgraded to 11. Need this figure this out asap. |
How about disabling all plugs in the session (not just bypassing) - the. Try and see if offline bounce works
#16
Can you check Setup > Preferences > Operation, look for the Misc. section in the bottom-right, and see what your Clip auto-fade value is set to? Try adjusting this to 0 ms if it is not already.
Additionally, what is your Bounce source set to: an Output (bus) or Physical Out?
Jordan |
#17
I have tried trashing preferences, and rebooted.
Not sure why I would want to disable all plugins. I need my plugins to work if I do an offline bounce. Clip auto-fade value has always been set to 0. I am bouncing 4 bus sources. |
#18
Just a quick test to find out if it's an issue or not
#19
Having this problem as well and its indeed caused by one or several plugins.
Working perfect when bouncing without any plugins active. Hope they fix this ASAP... |
#20
Resurrecting an old thread and I guess no one cares about PT11 anymore, but here's an image showing the unwanted fade-in added to offline bounces.
offline bounce different than realtime bounce | grant howarth | Pro Tools 11 | 8 | 12-08-2013 09:29 PM |
Offline Bounce | DonaldM | Pro Tools 11 | 6 | 11-17-2013 08:56 PM |
OK, but seriously, OFFLINE BOUNCE! | Kris75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 120 | 04-09-2013 06:55 AM |
Offline bounce | spyfly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-21-2007 12:50 PM |
Offline Bounce? | bboiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-12-2005 02:38 PM |
