Old 04-03-2012, 07:40 AM
Blue Ranga Blue Ranga is offline
Default Virtual Instruments (Xpand2) not installing correctly
Whenever I install Pro Tools 10 (I have not upgraded from a previous version) it always either comes up with 'The Factory Content was not found' or it won't show the message, and instead the drop down menu will show 'none' when it should show the categories for the virtual instruments.
Also, when I've tried to install the virtual instruments via the disks, it shows 'Please insert the disk: 1', and I have tried using all three disks that came with it, and none of them worked.
If someone could give me a pointer in what might help this problem, I would be highly grateful.
Old 12-23-2012, 10:23 AM
jbmuzic jbmuzic is offline
Default Re: Virtual Instruments (Xpand2) not installing correctly
I know this is an old post, but I thought I'd reply anyway just in case anyone is still running into this problem. I can't help you with the Factory Content error, but I can provide some advice for the "Disk 1" error. I ran into this while trying to install PT10 on my system and, after some frustration, found that it was due to the Avid Virtual Instruments file that was leftover on my system from a PT10 demo I had installed. Uninstalling the PT10 demo does NOT remove the virtual instruments installed with the demo. If you installed the demo, that could be your problem. Here's my thread where you ca see exactly what I did to resolve the issue: http://duc.avid.com/showthread.php?p...=1#post1991418
Computer -
2012 Dell XPS 8500
Windows 7 Home Premium 64-bit
Intel Core 17-3770 3rd gen CPU @ 3.40 GHz
12 GB RAM
Audio Interface -
Presonus FireStudio Mobile
Pro Tools 10
Xpand2 - How to get list of instruments ScottieTraxx Virtual Instruments 3 02-26-2017 09:44 AM
Why no virtual Keyboard in Xpand2! teacherman Virtual Instruments 1 08-22-2013 11:52 AM
Installing PT10 Virtual Instruments kyoung91 Pro Tools 10 2 02-21-2012 12:01 PM
Structure not translating EXS instruments correctly PhilBuckle Pro Tools TDM Systems (Mac) 16 06-01-2010 04:41 PM
6.0.1 not installing correctly ProfessionalTool 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-03-2003 09:22 AM
