Old 07-30-2011, 04:36 PM
michaeldurig michaeldurig is offline
Default Mac Os 10.6.8 Pro Tools 9.0.3 003R
I have updated my midi drivers for my 003R. I am having latency trouble in my audio tracks. Set up all Mac functions, Bluetooth, Airport, according to Avid Just updated to 10.6.8 before I realized that problem involved. Any solutions to my situation?
Old 07-31-2011, 06:33 AM
daeron80 daeron80 is offline
Default Re: Mac Os 10.6.8 Pro Tools 9.0.3 003R
What sort of latency trouble? Also, did you use the Combo Updater for 10.6.8 or System Update? The former is recommended. It can be installed over the System Update if needed.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 07-31-2011, 03:16 PM
Thanks for your help. I plugged in my guitar and when I play it echoes rather than play straight through. I am not sure if I am missing a setting in PTs or not. My machine is a IMac i 7 with 16GB of ram. I am sure there are enough resources.
Old 07-31-2011, 04:22 PM
Yes, that's recording latency. It's dependent on the Hardware Buffer setting. In Pro Tools, Setup menu, Playback Engine, the top item is H/W Buffer Size. Set that as low as it will go. The lower it is, the less recording latency you will have. The higher it is, the more mix power you'll have. All digital recording systems have some latency. Most people don't notice it much when the H/W Buffer Size is 64 or less.
David J. Finnamore
Old 08-02-2011, 12:40 AM
GW GW is offline
* First of all try to go to Options/Low Latency monitoring and record that way and see if that is to your satisfaction (you wont use your plugins that way, but will get rid of the latency).
* Secondly do as recommended above, lowering your buffer size
* If you have heavy plugins on your mastering track you can disarme the delay compensation for only that track by View/Delay Compensation and after that you go down under the fader in Mix-view and click right-click on the green dly and disable it so it turns grey. DOES anyone have a good explanation to why this isn't done from the start, since this is the final channel of the chain and doesn't need to be compensated on the other tracks?
(This doesn't solve your problem with recording latency, this is regarding to the next step in your workflow and for getting it to work as supposed to...)
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Digi 003r not supported in pro tools 10? RegenerationMix Pro Tools 10 4 07-25-2013 09:25 PM
Pro Tools can't find 003R unless I restart PT Ty Ford 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-03-2013 07:14 AM
FS:Digidesign 003r Includes Pro Tools 8 LE Software philip888 Buy & Sell 1 03-20-2013 04:22 PM
Help setting up 18 inputs Pro Tools 9 003R+ geniusboots 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-02-2012 01:10 PM
Lightpipe and Pro Tools via Digi 003R BabyG General Discussion 5 02-07-2009 06:57 AM
