Old 04-14-2011, 02:07 PM
sweetambition sweetambition is offline
Default Pro tools 8 Midi Connections - keyboard not recognised when using audio samples
I am very new to pro tools and really need help with the following
1) I have myprokeys 88 sono keyboard hooked up to pro tools 8 via the mbox mini 2 and I have configured the midi studio options so it recognises my kebyboard... this works fine when I create an instrument track and use a plug in... for r.g mini grand (piano)
However when I create an audio track and load up a sample or a loop.. I cant control this with my keyboard...
Could someone please tell me how I can use my keyboard to control audio samples as well as plugins... I have been troubleshooting for days now...
Thanks...
Old 04-14-2011, 04:41 PM
Default Re: Pro tools 8 Midi Connections - keyboard not recognised when using audio samples
How would it work to put a sample or loop on an audio track? I'm not a midi expert, but that doesn't seem right. I would be calling up an instrument track and Structure Free and then drag loops and samples into Structure and assign to keyboard midi notes. I would search youtube and the airusersblog for some tutorials
Old 04-15-2011, 01:08 PM
Thanks for your reply,.,
But when i browse my samples & loops and select them they cannot be dragged onto a midi/instrument track.. they will only drag onto an audio track it this not meant to happen?
Old 04-15-2011, 01:33 PM
ondruspat ondruspat is offline
As Albee was saying, you need to use a software sampler to play loops and sampler from your keyboard, otherwise you bring them into your session on audio tracks and manipulate them as recorded audio.
I'm pretty sure that Structure Free should be in your inserts under "instruments", you initiate it on an insert on your instrument track. Do some Youtube searches for Stucture, I'm sure you'll find a bunch of instructionals.
"Sometimes having limits keeps you sane"- Albee1952
Old 04-15-2011, 06:58 PM
zedhed's Avatar
zedhed zedhed is offline
Correct, this is how it is designed to work.
Incorrect, this is not how it is supposed to work. You don't drag n drop samples into an audio track unless you want to manipulate them as an audio track.
If you drag n drop samples into a plugin such as Structure, you can then trigger them with a keyboard, as the previous two posts have said.
If you go here;
http://www.airusersblog.com/structure/
there are lots of great tutorial videos on all manner of subjects. It is worth signing up (Free) to get access to them.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 04-21-2011, 08:07 AM
Default Re: Pro tools 8 Rewire - Fl7 - Bounce
K all, thanks for your help will check this out..
On the subject of Pro tools!
I now have another issue anyone might be able to help me with..
I am usinf fl7 and pro tools via rewire as I want to mix down all my old tracks i made in fruity in pro tools and some new sounds then bounce them
Ive hooked everything up to the mixer etc,,, and i get sound and pro tools plays it.. but how
do i bounce out rewire tracks,, when i choose bounce to disk.. I only get the samples I added in pro tools and nothing else.. it does not export the fl7 sounds.. even though they play through pro tools
would be very greatful if anyone could help .
Assign Samples To Midi Keyboard. imperialcarter macOS 1 02-08-2012 10:29 PM
003 not recognised Audio MIDI Setup (osx Lion) SonicPictures 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-23-2012 06:49 AM
Pro tools 8 will not recognize M-Audio midi keyboard jonslaten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-12-2010 10:11 PM
Selecting samples with keyboard or MIDI banks avaktar Virtual Instruments 1 06-29-2009 12:08 PM
mbox -triton keyboard- midi connections SugaHoneyIceT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-25-2002 11:03 AM
