Old 04-14-2008, 05:46 PM
cnswilliams cnswilliams is offline
Default Desktop PC under $500?
Hello,
I am new to ProTools LE and I am currently running 7.3 on my laptop. After about 16 tracks and a few RTAS plugins she started to bog down pretty bad. I was wondering if you guys had any recommendations on a PC that will handle this stuff a little better. Maybe around 500 bucks if possible.
Thank You,
Chris
Old 04-14-2008, 08:09 PM
sw rec sw rec is offline
Default Re: Desktop PC under $500?
We can't help you without some specific info about your system. Note:
http://duc.digidesign.com/showflat.p...part=1#1135485
That being said, are you using an external drive for recording? What's your processor speed, and how much ram? The last time I priced robust enough laptops for Pro Tools it looked like around 1200 bucks. I'm wondering if what you have is upgradable with more ram and a good firewire external drive.......
Old 04-15-2008, 01:18 PM
Im am using an external hard drive (7200 rpm) via usb and the Mbox 2, which is also USB. The laptop I am using is about 3 years old. It has one gig of ram and an Intel Celeron processor. Obviously not the greatest setup for Pro Tools. I guess what I'm wondering is if I buy a new CPU tower, what would be a worthy processor to look for. I'm pretty sure anything would be better than what I am using at the moment. Check out this CPU http://www.shopping.hp.com/product/r...X614AA%2523ABA
Thanks for your time
Old 04-15-2008, 10:25 PM
mano111 mano111 is offline
this HP seems like it could work but a few thing about it and yous setup
1. windows vista is only supported for busness and ultimate. I would try to downgrade to XP.
2. looks like it has integrated graphics card. this may or may not work. your gueass is as good as any. if its problematic you will need to add a card and disable onboard in the BIOS.
3. you will also need a digi approved firewire card and HD. recording to USB is not supported, still it might work.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
What Mac desktop for LE 8, 9, 10 Innerfear3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 27 02-06-2012 12:10 PM
Desktop DF Desktop DB dave2005 Tips & Tricks 2 09-06-2006 10:41 PM
I'm getting a new desktop GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-26-2005 05:18 PM
Desktop Pic colnago 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-27-2004 09:51 PM
Just For Fun - What's On Your Desktop? BigRedButton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 01-24-2002 11:59 AM
