Old 02-27-2010, 11:07 AM
sean shannon sean shannon is offline
Default Length of PCI HD cards
How long are the cards? I think I have a 12" clearance in my PC box. Is that enough space?
Check your mix in mono.
www.mixingtheband.com
Old 02-27-2010, 11:34 AM
GtrDude GtrDude is offline
Default Re: Length of PCI HD cards
I think I read somewhere that they were 12.5 inches.
I also think they have to go into a 75w slot.
But I'm not sure about that either.
GD
Old 03-02-2010, 01:44 PM
Thanks! Can anyone confirm this?
Old 03-02-2010, 09:13 PM
sunburst79 sunburst79 is offline
I would swear that DTS answered that they were exactly 12 inches once. Its been a while back but I did kinda make a point to remember that it was a even number and not a fraction.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-03-2010, 06:29 AM
smfelton's Avatar
smfelton smfelton is offline
They are standard full length PCI which is 312 mm (12.283 inches) as far as I know.
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Old 03-07-2010, 03:38 PM
Thanks guys!!
Old 03-15-2010, 02:14 AM
Phil O'Keefe Phil O'Keefe is offline
Yup - just a touch over 12", but not 12.5".
Phil O'Keefe
Old 03-19-2010, 09:09 AM
kilroyrock kilroyrock is offline
I had to use some tin snips, and cut a part of my hard drive bay out of the way to get it to fit.
Old 03-19-2010, 10:19 AM
propower propower is offline
Last I measured was 12 and 5/16.....
Why almost every case until we get to the really huge ones is only 11.4" (290mm) before it hits a hard drive cage or something is a constant wonder to me
-Lee
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 03-20-2010, 05:10 PM
So did I... and it's otherwise not exactly a small case either. But that's not Digidesign's fault - they're full length PCI-x cards; it's our cases that aren't to spec and don't actually support full length cards.
Phil O'Keefe
Drawn MIDI note length only staccato notes, regardless of note length kingofallwookies Pro Tools 11 2 02-07-2014 08:10 AM
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 03:39 PM
Copied region length auto-adjust to paste location length? greglawrence Tips & Tricks 4 10-23-2011 01:46 PM
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in phatbeatstudio Pro Tools TDM Systems (Mac) 6 10-16-2011 12:35 AM
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! A Spooner Tips & Tricks 6 07-08-2009 07:55 PM
