Old 02-08-2018, 01:36 AM
oscar_wonderboy oscar_wonderboy is offline
Default Video Engine Fail "Waiting for the video engine to launch"
Hey guys, I can't get the video engine to run properly, when I try to enable it from the "Playback Engine" menu, it just says "Waiting for the video engine to launch".
I have googled a lot (it seems to be a fairly well known thing) and tried various things: (Deleting the "workspace" file from shared/users, Deleting Avid Quicktime engine from shared/users, force quitting the avid quicktime app from activity monitor etc, but nothing helps...) Anyone had the same experience and solved it? PT 11.3.0, OSX 10.12.6
MAC PRO 12-CORE, 64 GB RAM
OSX 10.12.6
PRO TOOLS 2018.4
LOGIC 10.4.2
Old 02-08-2018, 01:47 AM
BScout BScout is offline
Default Re: Video Engine Fail "Waiting for the video engine to launch"
Why are you on Sierra?
ProTools 11.3.0 does not support Sierra. Only can go up to Yosemite. so... good luck
http://avid.force.com/pkb/articles/e...tibility-Chart
Old 02-08-2018, 01:55 AM
ah ok, didn't realize. But the weird thing is that it has been working up until a few days back. So it def works on Sierra.
OSX 10.12.6
PRO TOOLS 2018.4
LOGIC 10.4.2
Old 02-08-2018, 02:02 AM
Never mind, upgraded to PT 2018
OSX 10.12.6
PRO TOOLS 2018.4
LOGIC 10.4.2
Old 02-08-2018, 02:55 AM
Problem still persists, even though I ”upgraded to PT 2018...
OSX 10.12.6
PRO TOOLS 2018.4
LOGIC 10.4.2
Old 08-14-2018, 01:22 AM
YichenWang YichenWang is offline
Default I sort of have a solution, but it doesn't work 100% of the time
It's worth a shot tho.
If you are on Mac, then make sure that you don't have Elmedia Video Player.(And never reinstall that **** ever again.)
That's step one.
Then delete AvidVideoEngine folder, which is located at Macintosh HD>Users>Shared>AvidVideoEngine. Then reboot your machine.
Go to avid.com, download the Pro Tools installer, open it and go to the "Codec Installers" install the codec, then launch Pro Tools application., go to Playback Engine, try to enable the Video Engine.
sometimes you need to switch your Playback Engine to a secondary option (something like, HDMI) then switch it back to your Audio Interface alone with the Video Engine.(This step is kinda superstitious, I don't really understand the reason behind this, but I'd better write it down!)
Hope that will work for you.
"You must enable video engine" - no video track Carsonic Pro Tools 12 0 01-05-2016 06:37 AM
PT HD Native 11.3 "Waiting for the video engine to launch" bigbuddy3 Pro Tools 11 7 12-25-2014 08:34 PM
Waiting for the Video Engine to launch nicolasvandooren Post - Surround - Video 8 02-09-2014 02:32 PM
"Waiting for the Video Engine to launch" error mrhood Post - Surround - Video 0 07-25-2013 01:28 AM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
