Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 01-16-2019, 08:59 PM
blastula blastula is offline
Default Session Template Question
When I create a session using a session template, the session folder is created on the designated Record disk, as expected. In the session folder is the expected Audio Files folder.
But when I record into the session, the audio files do not go into that Audio Files folder, but into an audio files folder out on the top level of the Record Drive.
How do I get the recorded audio to go the desired Audio Files folder. (When Creating the template, the project did not exist, so I could not designate that folder!). How is it done??
Thanks!!!
Old 01-16-2019, 09:06 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Session Template Question
Hi check the disk allocation within the session . I think it would have pointing to a pre-fixed place ( not shure ) .
- Jesus Alvarado -
Windows 10 Pro 64 bit - i7 CPU 4770k
Asus A97-AR mobo - 32gb DDR3 ram
Samsung 850 evo SSD 500gb - Radeon 470rx
Corsair 750w PSU
Lynx Aurora 8
Clarett Pre 8 X Thunderbolt - Protools Ultimate
Avalon 2022 - Octane 8 - Scarlett Dynamic 8pre
Uad 2 quad - Waves Gold
McDsp Emerald - Duy Everpack
Tc Powercore Firewire
Old 01-17-2019, 12:26 AM
BScout BScout is offline
Go into your template and look at disk allocation. Make sure "custom allocation options" is not checked in your template.
If it is checked, it will send all files to one directory (for anything using that template) that you specify as the root directory.
If it is not checked, it will do Pro Tools default behaviour and record to the session's own folders next to where the session is saved.
Pro Tools Ult 2018.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 01-17-2019, 01:37 AM
nope. no matter which way i set disk allocation (customize option), the newly created session will not put new audio in an audio folder with the session...it creates an audio folder out on the same level as the session folder.
Old 01-17-2019, 07:06 AM
EdwardWilliam's Avatar
EdwardWilliam EdwardWilliam is offline
Have you tried Save Copy In, select the drive you want, then open that new session?
Edward
Old 01-17-2019, 12:13 PM
Can you post a screenshot of your template's disk allocation?
Old 01-18-2019, 01:46 AM
Here’s why that question confuses me. (and my confusion with the topic, in general)
A Template is created from a Session (call it Session A) using the Create Template command.
Then, a session (call it Session B) can be created using that Template file
I can view disc allocation for session A or for Session B, but don’t have a way to view disc allocation for an actual Template file.
Besides, given that Pro Tools likes to keep a session’s audio files in an Audio Files Folder inside the Session Folder, the disc allocation for Session A is not going to work for Session B, unless there is an over-riding option like “Place New Audio Files folder in New Session Folder”...which doesn’t seem to exist.
Is this making sense?
Old 01-18-2019, 01:54 AM
PS
Frankly without the above-mentioned non-existent common sense command (“Place New Audio Files folder inside New Session folder”), I don’t even understand the practicality of templates. I do see that the workaround of using Save a Copy As would work, but..... really? I must be missing something.
Old 01-18-2019, 08:09 AM
Shippley Shippley is offline
(Note: In my opinion, you should not use templates unless you can recreate the template on your own)
Try this:
1. Delete your existing template that isn't working properly.
2. Open the parent session that you wish to use as the template.
3. Open Disk Allocation window (under Setup menu)
4. Un-Check the "Custom Allocation Options" box
5. Make sure "Use round robin..." is also un-checked.
6. Click "OK" in the Disk Allocation Window.
7. Save the session
8. Save as a template
9. Make a new session using your new template.
10. Report back to this thread with your results.
Old 01-18-2019, 09:30 AM
I can view disc allocation for session A or for Session B, but don’t have a way to view disc allocation for an actual Template file....
Change the file suffix from .ptxt to .ptx, then you can open the file, alter whatever needs altering, save it, then change its suffix back to .ptxt
rich@richbreen.com
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Importing a mix session template into a record edit session bryced87 Pro Tools Software (Mac) 1 04-27-2012 05:24 AM
question about session template/folders djcream 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-06-2010 09:48 PM
How...Create New session with Session Template TDelmar Tips & Tricks 5 10-22-2008 09:29 PM
session template question 16yearsjeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-10-2007 11:34 AM
Custom session template question/confusion ScottFB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-24-2004 12:43 PM
