Old 01-06-2019, 02:52 PM
danonbass danonbass is offline
Default Glitchy Problems With Reason10 as Rewire
I'm getting some glitchy issues while using Reason10 as a rewire in PT. When I pull up a loop in Reason it will sound normally in the preview, but will change when I choose and load it into Reason. The sound change is almost like it's being run through a Lo-fi effect. The second issue I get is a rhythmic note being played at C1 on all Reason instruments. I can see it on the Midi Input of the instrument, and when I record a Midi Performance it shows up in the performance as a short consistent Midi Note at C-2. None of this happens using Reason alone or as a rewire in Logic. Just Pro Tools.
I may just be in upgrade territory, but I'm hoping there is just some set up issue I haven't been able to find.
PT 11.3.1
Reason 10.2.1
OS 10.10.5
ApolloQuad
Old 01-07-2019, 12:24 PM
Default Re: Glitchy Problems With Reason10 as Rewire
Thinking this might be a compatibility issue between Reason10 and PT11 I upgraded to PT 2018.12 and Reason10.2.2. Same exact issue still there.
Old 01-18-2019, 04:12 AM
Can't help with the loop thing but with the MIDI note business I'd suggest grabbing the free snoize MIDI utility and run that standalone. It will tell you what's going on between your keyboard and computer.
Jack
QAPLA!
rewire problems perraultm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2012 03:52 PM
Rewire problems Deano1974 Pro Tools SE and Essential (Win) 0 03-26-2011 03:02 PM
rewire problems garrydrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-29-2008 04:47 AM
Rewire Problems Buzzhound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-09-2003 09:28 AM
Rewire problems...help! Boogie Pro Tools TDM Systems (Mac) 4 06-20-2003 12:52 AM
