Old 08-04-2018, 10:49 AM
Trey803 Trey803 is offline
Default AIR Hybrid 3
Hello,
I am brand new to midi and just purchased an MPK225 which comes with AIR Hybrid 3. I've got everything up an running in ProTools but I have a few issues/questions.
I watched this video
https://www.youtube.com/watch?v=hP6395Ykv_E&t=600s
At 8:45 in the video the aftertouch is activating the morph1 function of the plugin. I have aftertouch turned on for the pads and the keys on my MPK225 and also have check the plugin to make sure that aftertouch is elected for morph1. Is there something I'm missing, when I hold a key or pad it does not activate morph1 as shown in the video demo.
Is there a way to display instantaneous note information without recording? I have armed the track and I hear the sounds but I do not see any action on the protools track, I have used the expand track to fit window to see all notes and still nothing. If I arm the track and start recording the note information is recorded and I can now see the notes. But if I am not recording I do not see anything.
Any help is appreciated.
Old 08-04-2018, 11:11 AM
Top Jimmy's Avatar
Default Re: AIR Hybrid 3
Check your MIDI input filtering. As I recall, after touch is filtered by default for some reason.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.4, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
[/I]
Old 08-04-2018, 11:57 AM
ChuckS ChuckS is offline
The amount of data with aftertouch can get quite large sometimes causing MIDI choke, Polyphonic aftertouch, even more.
PT 2018.7 DP 9.51 VEP 6.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1803)
PT 2018.7 DP 9.51 VEP 6.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6 (end of the OS road for the 2011 Mini)
Old 08-06-2018, 07:15 AM
That was exactly it. Thanks for the tips.
Any idea on why my MIDI notes are not visible unless I am recording? I know it won't keep track of the sequence of notes, but shouldn't I be able to see the instantaneous note(s) on the midi track without recording?
Old 08-06-2018, 08:15 AM
Stig Eliassen's Avatar
Do you mean View (menu) > Other displays > MIDI input display?
Studio rig - Pro Tools|HDX 2018.7 | Logic Pro X | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5
Mobile rig - Macbook Pro i7 w/16GB RAM | UA Apollo 8p | Pro Tools|HD 2018.3 | Logic Pro X | OS 10.12.6
Old 08-07-2018, 03:46 AM
You would think so but that's not how it works in PT.
Upgrading from Hybrid 1 to Hybrid 3? tuomiopäivä Virtual Instruments 2 01-11-2016 12:01 AM
PT 8.0.3 no Hybrid 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-01-2010 05:28 PM
Hybrid ? dbahardstyle Virtual Instruments 1 02-15-2010 03:55 PM
hybrid ... metascanner Virtual Instruments 6 05-30-2008 02:34 AM
so how is Hybrid? 16yearsjeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-23-2006 02:37 PM
