Re: Importing Audio vs Session Data
As to the second half of your question, about populating a Template with Session Data, does the "Automatically Copy Files on Import" option from the Preferences Processing page work for that?
PT 2023.12 / Mac Mini M1 16gb SSD / OS X 14.2 / UA Apollo |
what gwhatley said is correct.
Use the workspace window. You can use the sort by path method or, while the drive/audio is offline, in the workspace browser select "all offline". Keep the workspace open, then connect the drive and do a relink, the selection of what was all offline should still hold after the relink, then do a copy and relink from the workspace browser (pointing to your new session folder)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Sent from my LG-H872 using Tapatalk
Garrard Whatley Seismic Post Audio Post Audio for Film and Television System/Hardware Info IMDb credits |
All the options are built right into that window. And that setting will stick until you close Pro Tools down. (so you can open/close/import as much as you want while Pro Tools is open and you don't have to look at the setting until the next time you start up Pro Tools from scratch)
Waveforms increase in size when importing audio file as session data import | myeviltwin | Pro Tools 2018 | 4 | 02-10-2018 02:20 PM |
PT 11.3 no longer importing audio files along with session data | jsbeeth | Pro Tools 11 | 3 | 02-25-2017 04:28 AM |
Can't find 16 bit audio files when Importing Session Data | DavidCaporale | macOS | 0 | 04-23-2015 08:50 AM |
MBox - importing session data, missing audio!? | spike.mk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-08-2009 08:42 AM |
Problems importing audio, session data, etc. | essay | Pro Tools TDM Systems (Mac) | 0 | 09-12-2006 10:18 PM |
