Old 06-30-2008, 11:10 AM
burningbusch burningbusch is offline
Default Transfuser - Rev always on in MARIO
I using the final release trial version. When I bring in a sliced audio file and process it using MARIO I find that MARIO always adds reverse slices even when reverse is turned off.
Anyone else getting the same results?
Busch.
Old 08-09-2008, 04:24 PM
grazhoppah grazhoppah is offline
Default yes, same problem for me
Hi bb,
i share your pain -- clicking Mario more than once always produces unwanted reverse variations. It's a real creativity killer....
I asked support about it and they could not reproduce it. They recommended I trash databases, transfuser preferences, and DAE prefs. Still no fix..... So i am wondering : have you figured it out??
Cheers!
gh
Old 08-09-2008, 05:36 PM
Default
No, I subsequently purchased the product so now I'm working with the full version. The issue remains for me. I used the Protools Pref and Database Helper to try to clean up everything. No change. I reported it as a bug as it's 100% reproducible on my machine.
My system is:
Protools 7.4
TDM Accel 3 PCI
G5 Dual 2.0 Ghz
OSX 10.4.11
I also have a MacBook 2.4Ghz DualCore Intel runing PT LE 7.4.2 on OSX 10.5.4. It does not exhibit this behavior.
Busch.
Old 08-12-2008, 06:43 AM
Wolfram K's Avatar
Wolfram K Wolfram K is offline
AIR Music Technology
Default
Hi everybody,
we have reproduced this bug.
It will be adressed in a CS update for Transfuser.
Thanks,
Wolfram Knelangen
Product Manager - A.I.R
Old 09-15-2008, 12:07 PM
Default Re: Transfuser - Rev always on in MARIO
There is a workaround I use to keep the flow
I click MARIO until i hear something i like, while monitoring the REV (reverse) edit pane. If I see that MARIO has created unwanted reverses, i just hold "Shift" and click on the bottom of the REV edit pane to return all slices to non-reverse status.
Just wanted to share this in case anybody else was experiencing the problem.
I continue to be AMAZED by Transfuser
Old 09-16-2008, 01:43 PM
I lucked out. I just moved to a MacPro and on this machine Transfuser works properly. On my old G5 and my MacBook, it did not.
Busch.
Transfuser Tip DonaldM Virtual Instruments 9 04-28-2014 11:05 AM
Transfuser DragonBlight Virtual Instruments 4 04-03-2010 02:29 PM
transfuser x 2 mafiacondon Virtual Instruments 10 03-05-2010 03:17 PM
installing Transfuser full on Transfuser trial wfasano Virtual Instruments 2 06-30-2009 04:14 AM
transfuser/ geeball Virtual Instruments 0 02-08-2009 10:05 PM
