Error Message When Bouncing To Disk
I am running ProTools 6.1 on a Mac G4 with OS 10.2. I have been using this setup for quite a while now. Only recently, when I attempt to "Bounce To Disk" I get an error message. It happens on only some of the regions that I select, but it happens every time I select one of those regions. I've tried "Convert During Bounce", "Convert After Bounce", all different file formats, opening the region in a new session, and even bussing the output of the region to a new track and re-recording it. No matter what I try, I get the same error message. Here's what is says:
"Could not complete the'Bounce to disk...' command because: Assertion in 'FF_AudiProperty.cpp', line 33. Someone please help! I'm outta business if I can't give people their mixes!!! |
Re: Error Message When Bouncing To Disk
No idea if any of these will help, but there are 4 items on a search for "assertion line 33" in the Answerbase:
Answerbase Results
Administrator Avid Pro Audio Community |
Thank you SOOOOO much!!! I must have changed my DAE playback, once I changed it back to the default (2), my bounces worked fine. I should start checking the answerbase more often.
Error Message when bouncing to mp3 | rtm | Pro Tools TDM Systems (Win) | 1 | 11-01-2010 02:37 PM |
Error message when bouncing to disk-help | mulady80 | Pro Tools M-Powered (Win) | 1 | 08-22-2008 02:21 PM |
Error message when bouncing to track (7.4) | Frank Kruse | Post - Surround - Video | 9 | 12-06-2007 12:49 AM |
Help! LE 6.4 error message when bouncing to AIFF | SlickDee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-26-2004 03:08 PM |
Error message when bouncing to disk | MB2001 | Pro Tools TDM Systems (Mac) | 2 | 10-25-2004 01:53 PM |
