Behringer Umc202hd setup
Hi
I have tried to setup my audio interface with Pro tools first. I have tried asio4all driver for Windows 10 but it does not give me hardware option but just suggests to use realtek built in sound as output. Is this normal as I have seen in YouTube that should be able to configure the behringer in thi hardware? If I use the defaults I get juddering sound. I only get normal sound with windows sound in driver so non asio. I'm not technically minded on this so forgive my shoddy description/requirement. I need the audio interface to be able to record and playback properly without issue. Any setup advice greatly appreciated thanks Alan |
Re: Behringer Umc202hd setup
Yes I installed the behringer Windows driver.
Thanks |
Is the driver ASIO or just WASAPI? Pro Tools First on Windows works best with an ASIO driver.
I have now installed the v2.23 Windows driver rather than the v4.x and it is working.
It gives me UMC202 Asio in the dropdown for playback and the hardware option gives me a white pop up box with minimal features rather than the black menu item I was seeing before. But at least I am getting playback and no juddering. I will test if for recording. Thanks for help :)) |
MIDI SETUP takes long to SETUP and doesnt SETUP | DartagnanSosa87 | MIDI | 3 | 01-28-2013 12:02 PM |
PT 9 setup problem..Where are the MIDI IN options in setup menu?? | Blickerding | Windows | 0 | 04-06-2011 02:44 PM |
Sweet Behringer FCB1010 Setup with 11r!!! | kulp_jr | Eleven Rack | 9 | 10-14-2010 09:17 AM |
behringer mx9000,behringer mx3282A,mackie 24/8buss | JOAN ROSALES | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-03-2004 12:21 AM |
"Edit MIDI Setup" Setup Menu Item is Missing! | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-08-2004 12:24 PM |
