Old 03-05-2003, 04:00 PM
sean shannon sean shannon is offline
Default ADAT and S/PDIF together
Is it possible to record 18 tracks at once with the 001? If I set my clock to ADAT to receive the 8 ADAT feeds, will the S/PDIF input click as they try to clock up?
Sean
Check your mix in mono.
www.mixingtheband.com
Old 03-05-2003, 07:26 PM
J. FO J. FO is offline
Default Re: ADAT and S/PDIF together
it is possible. what you will need, is a master clock. if you want to use optical sync, the source will need to be able to send the clock source to the spdif device. or, vice versa. you could send the clock source from the spdif device to both the ADAT converter and to the 001. what equip. do you have? that would be helpful.
Jeremy Forbis
Old 03-05-2003, 09:09 PM
rnt_u_listnng rnt_u_listnng is offline
Sean,
I do exactly what you are describing. I have a Digimax 96 and a HEDD 192 connected to an 001. I set PT to sync to the HEDD (via S/PDIF) and use the clock out of the HEDD to sync the Digimax via BNC cable. Works great.
BTW, there was another thread that suggested it is better to sync over S/PDIF than optical with all other things being equal. You can search to find the thread. So if you have a good clock available via S/PDIF you may want to use it in preference to your optical unit.
Good luck.
Old 03-05-2003, 09:36 PM
StainedClass StainedClass is offline
How can I do it with a 001, o1v with adat and firestaion
only the firestaion has wordclock
StainedClass SC
Old 03-05-2003, 10:39 PM
I probably need more information on your setup but try this and see if it works. I assume the 01v is hooked to 001 via coax and the firestation is connected via adat. You should be able to use your firestation as the clock master, sync your 001 to this and sync your 01v to the "stereo in digital". Make certain you have the stereo in channel connected via coax connection to the 001 to carry the clock signal. You can check on your 01v console readout to assure you are getting a clock input from this source. Someone else may know better than I whether this will work.
If you wanted to use the 01v as the master, I don't think you have anyway to get the clock back to your firestation. If it is like the digimax 96, you have to use the word clock bnc to control it.
Hope this helps.
Old 03-05-2003, 10:57 PM
After looking back at your question, it looks like you probably have the fs coming in via adat to your 01v and then what? Adat and coax out to 001? If this is the case you can sync 01v to optional i/o and sync 001 to whatever connection is coming from your 01v. In this way, the fs can act as clock master.
Old 03-05-2003, 11:11 PM
Thanks I will try it
StainedClass SC
S/PDIF versus (or, along with?) ADAT futz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-31-2007 01:48 PM
what is ADAT? what is S/PDIF? digimike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-20-2006 06:30 AM
Is it possible to use Optical ADAT & S/PDIF.... thomasdamien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-15-2006 07:27 PM
ADAT to 4x S/pdif coaxial ??? Bob Legs General Discussion 1 01-27-2005 08:15 PM
ADAT -- S/PDIF breakout box sbertrand10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-18-2000 06:16 AM
