Old 09-22-2017, 07:17 PM
asatluvr asatluvr is offline
Default missing project...
I am working on a mix ..in it's late stages...but the project seems to have disappeared...I can't find the files...I certainly didn't delete it..any suggestions..worried in Austin
Old 09-22-2017, 07:54 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: missing project...
Have you had a look outside of Pro Tools by just opening the session folder>Audio Files folder on your recording drive to see if they are physically there?
Also try opening your latest backup in the Session folder>Session File Backups folder on your recording drive.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 09-22-2017, 10:55 PM
I have combed my computer and all relevant folders...the song seems to have vanished
Old 09-23-2017, 08:12 AM
dr_daw's Avatar
dr_daw dr_daw is offline
Just to clearify you're referring to a session? as a project is a cloud session. I'm going to assume you don't do backups. It would be real simple to move on if you were able to load the session from your backup drive.
Another good example to why you should do daily backups when you're working on a session.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2018.10, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 09-23-2017, 10:31 AM
The Weed's Avatar
The Weed The Weed is offline
Open the session - if it is a session not a project - open the Clip List and set it to show the full path of the files. That should tell you where they are.
Did you inadvertently use an external drive for the session files and that external is no longer attached?
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-23-2017, 11:56 AM
Default Re: missing session...
Ok it's a session that's missing...not a project...my fault...some of the old session files exist from when I 1st started the tune; but none of the newer renamed files...the session folder is empty...I have combed this computer for these files but once again they seem to have vanished...the song had 10 tracks on it...the old original files only contain the starting of the drum build....man I can't imagine having to completely re record the entire tune....breaks my heart
Old 09-23-2017, 12:05 PM
Can you answer all previous questions really clearly: what was in Session folder>Session File Backups? Did you have an external drive (or network share ore removable media) attached that no longer is? (if so look there).
When was your last manual backup or archive made?
Computer details? Filesystem type? Drive make/model?
You sure all content was in the session folder?
Check the trashcan for your files?
You sure you are searching for the right file names?
How exactly are you searching for these files. e.g. a Mac you should be using find to search for any files with the right file extension, or on Windows the DIR command (with /S option). Don't rely on indexed search utilities like Spotlight or the equivalent on a PC.
Old 09-24-2017, 11:20 AM
The Weed's Avatar
^^^^ This.
And did you set the Clip List to show the full path of files so you know where they were saved?
Old 09-24-2017, 12:08 PM
Terry Wetzel Terry Wetzel is offline
Did you trash prefs. in PT's? If you did that deletes the files.
Old 09-24-2017, 12:12 PM
zedhed's Avatar
Trashing prefs does/should not delete session files. Session files are stored outside the realm of Pro Tools preferences.
HD 96I/O
Win 8.1 Pro
Create New Project - There was an error posting the project. descendant Pro Tools | First Discussion 13 04-24-2016 06:35 PM
Missing names of audio clips in project Seti Orion Pro Tools TDM Systems (Mac) 1 07-25-2008 06:44 PM
Audio files missing in project bug?!? Dizzi45Z Pro Tools TDM Systems (Mac) 5 04-10-2008 11:36 AM
missing plugins? also Cant use Guitar rig 2 in 24/48 project urcool 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-20-2007 07:12 AM
