Re: How to make a rise
Sure, it can be harsh, but that's where an EQ (and sometimes distortion) will help. Keep at it.
Raoul,
Every VI with a reputable name has many many rises and options. If you don't get this the way you want it let me know and link to a example and I can make a few rises with our arsenal of synths and VI to your liking
Awesome thats great thank you
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Thank you everyone who chimed in on this thread I managed to create what I wanted with all you tips and advice :)
Raoul Crane
Great you got it sorted out Raoul, maybe this can help too
https://youtu.be/4cSL27qnJaY
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
#16
Excellent advise all round, but if you use risers often, you can try 'The Riser' by Air Music Technology, which has loads of rises and falls that you can modify to taste. http://www.airmusictech.com/product/...r#.WQhsVSJ0Rpg I use risers and transitions quite often, and more often than not I'll have 3 or 4 tracks for my riser containing a combination of some of these elements: synth sweeps, noise sweeps, manipulated cymbal swells, reverse cymbals, reverse reverb, sometimes 2 different risers from Riser...you get the picture. It's up to your creativity to create suitable risers for any given song. In combination with drum arrangements etc you can achieve very dramatic results with a little work. Best of luck, hope this helps...
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#17
I might try the trial version, do you no what the limitations are ??
Raoul Crane
#18
You can also use one of the many crash sounds from a Xpand2! kit or Boom, either bounce, commit or bus it to a audio track and then use the audio suite reverse plugin.
To me it's usually the end of the reverse crash that might sound harsh depending on what crash sound you use. To de-harsh it you can try rolling off some high-end at the end of the reverse crash with the built in eq in pro tools. Maby from 7 or 8 k and above. |
#19
I've forgotten, but you can visit the site and download the trial.
#20
I always bussed the cymbal through a large reverb and or maybe a bit of tempo matched delay, recorded then reversed it, placed it where it goes and automated the volume swell. That works far better than adding the verb after the reverse in my experience. Sometimes I have to do it a few times to get the verb tail how I want it.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Bass Rise? | domdompompom | Pro Tools 12 | 1 | 10-27-2016 03:16 AM |
FS: Slate Digital plugins - NI Rise and Hit | PeterKorcek | Buy & Sell | 5 | 01-23-2016 08:46 AM |
WOW this is the Coolest Ever!!! Roli Rise | Southsidemusic | General Discussion | 3 | 12-20-2015 06:18 AM |
Dramatic pitch rise effect - how to?? | phillyt2k | Pro Tools 10 | 9 | 04-28-2013 11:35 AM |
CPU and System Levels rise after vocals end... | Target Earth Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 01-08-2002 12:54 AM |
