Old 03-09-2015, 02:17 PM
pribb1 pribb1 is offline
Default Can't change HW Buffer Size
I recently upgraded from PT8LE to PT11.
I'm trying to reduce the hardware buffer size from 256 samples to 128, but there are no other options available in the Playback Engine. Everything else seems to be running ok.
My hardware is a Roland Quad-Capture. Advice?
My Tech Specs
Operating System: Windows 8.1 64-bit
CPU: 4th Gen (Haswell) Core i5 3.5GHz
Graphics/Video: Intel HD Graphics 4600
Maximum Resolution: HDMI: 4096 x 2160 @ 24 Hz, 2560 x 1600 @ 60 Hz; DVI-D: 1920 x 1200 @ 60 Hz; VGA: 1920 x 1200 @ 60 Hz
Memory – Included: 8GB DDR3/1600 (4 slots/2 filled)
Plus: 2 4GB1600 - Lifetime Memory PC3-12800 DIMM 4GB
Plus: 1 InstallRAM - Install: 4gb1600
Memory – Max: 32GB (install in pairs)
Storage – Included: 1 TB Seagate Barracuda (SATA 6.0 Gb/s)
Optical Drive: DVD-RW
USB Ports: 4 x USB 3.0 ports (4 rear); 4 x USB 2.0 ports (2 rear, 2 front)
PCI Slots: 1 x PCIe 3.0/2.0 x16 (x16 mode, gray), 3 x PCIe 2.0 x1
Video Ports: 1 x HDMI, 1 x DVI-D, 1 x VGA
Old 03-09-2015, 02:24 PM
Default Re: Can't change HW Buffer Size
I have bad news and bad news, and more bad news... hhttps://www.google.com/search?q=Roland+Capture+siteduc.avid.com
That interface is unfortunately a bit of a train wreck, as is Roland's non-support. You can start by looking over all those other posts on DUC. I would not waste too long on this, you may be much better off dumping it and getting just about any other interface, from Focusrite, UAD, MOTU, ...
Old 03-09-2015, 02:34 PM
mesaone mesaone is offline
Quit Pro Tools, then change the buffer size from within the Quad Capture Control Panel.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 03-09-2015, 03:05 PM
Thanks Mesaone. You always answer my questions. Will try it tonight.
Old 03-09-2015, 04:42 PM
My RME interfaces are the same way - the buffer size has to be changed from the interface's control panel. Only the current buffer size is shown in the Playback Engine dialog.
So, When change H/W Buffer Size...... gonsdeejay Pro Tools 11 0 07-29-2013 09:12 AM
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Can't Change Buffer Size? sajack23 Windows 5 08-05-2012 05:29 PM
How do i change my buffer size? 479succeed Windows 11 03-24-2012 11:44 PM
PT9 / Buffer size won't change narapo Windows 3 08-15-2011 02:59 PM
