Old 01-04-2015, 03:46 AM
kwassen kwassen is offline
Default Field recorder guide track "select areas to search" doesn´t work
I just upgraded fom PT 10 on OSX 10.7 to PT 11.3 on Yosemite. Everything seems to work fine, except when i try to select areas to search in the field recorder workflow, the window opens up empty and i´m not able to select any drives or folders. I can work around that by placing the folder in the sidebar and selecting it there, so the actual process works fine. Does anyone else experience this behavior? Of course i trashed preferences and repaired permissions and it
doesn´t matter if it´s an existing or new session. I´m guessing this is caused by a setting in Yosemite because the window always opens up very slow. Hope someone can help. Thanks and Happy New Year!
Old 02-03-2015, 11:02 AM
simonchase simonchase is offline
Default Re: Field recorder guide track "select areas to search" doesn´t work
I'm getting this too
Did you find a solution?
PT Ultimate 2019.5 - Mbox 3 Pro ---- MacOS 10.12.6 - Mac Pro (Mid 2010) - 2 x 3.46 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 RAM - SSD Startup Disk ---- AJA Kona LHi PCIe
Old 02-04-2015, 05:10 AM
I got a fix (ish)
I just pressed "Open" on the blank screen then right clicked and selected "Modify". Then it left me search wherever I wanted
Old 02-04-2015, 06:16 AM
noiseboyuk noiseboyuk is offline
I thought this was going to be another thread on the extremely irritating bug that hasn't been fixed since PT9, where PT not only searches where you ask it too, but also matches EVERY SINGLE FILE IN THE PROJECT, creating sometimes hundreds of false matches that you have to sort and delete.
Drives me insane. I have to figure out really complex workarounds in multiple projects to stop it becoming totally unworkable. And seriously, how hard is it to code the following:
"Only search and return results from where the user asks".
That's it. Nothing more complicated than that. How long does that take to fix, seriously? Phh, and there are Pro Tools users who claim Avid jumps through hoops to every whim of the post community - HA.
Guy Rowland
www.guyrowland.co.uk
PT 2018HD; W10 Pro; i7 7820X; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Old 02-04-2015, 07:35 AM
Originally Posted by simonchase View Post
I got a fix (ish)
I just pressed "Open" on the bank screen then right clicked and selected "Modify". Then it left me search wherever I wanted
No, I found no solution, but Your workaround is better and faster than mine.
Thanks!
Old 02-07-2015, 08:06 AM
stustan stustan is offline
Same issues PT11.3 on Yosemite 10.10.1.
simonchase, thank you for the work around!!
Old 04-12-2017, 11:53 PM
karaho karaho is offline
I have this problem too. Maybe I am dumb, but i cant even click OPEN on "select areas to search" dialog window.
HTML code is On
Field Recorder Guide Track matching time code error cyberdote Post - Surround - Video 3 02-26-2014 06:04 PM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
"Improved" Field Recorder Functionality in PT10 simonchase Post - Surround - Video 5 03-21-2012 06:00 PM
Expand to field recorder guide track crashing protools JChappell Post - Surround - Video 2 02-09-2012 11:57 AM
editpack track select gives "No Valid Tracks"??? jmattchan ProControl, Control|24, Command|8 1 05-27-2009 05:44 AM
