Old 10-01-2014, 03:02 AM
Cryos's Avatar
Cryos Cryos is offline
Default 10.3.9 bug reports
1st bug I discovered in PT10.3.9 is regarding Automation preview mode.
When in preview after writing plugin automation the little green automation selector on the actual track does not turn red. Seems too be only in 10.3.9.
Need a fix.
2nd Bug EQlll AAX. Tthis has been a long standing Bug and amazes me how Avid still have not addressed this in Freakin years has too do with EQlll AAX.
automation does not write properly or not at all when doing snap shots or real time moves. I have experienced this on all platforms from HDX, too Native and CPTK systems Ever since the inception of AAX!!!! Also the direction in which you move the mouse too widen the Q in the AAX version vs the RTAS version is reversed!! bottom line is( and I'm gonna rant now) this has been Happing for FREAKING Years and AVID have never fixed this issue. I certain it's been reported many times too no avail. Makes me truly wonder what the Good Ole folks at AVID actually do. Seems like no one gives a flying hoot.
3rd Bug Has too do with AAF/ OMF imports in 10.3.9, was recently working on a project where we kept getting regular updates, so every update we'd open the AAF 1st to make sure all data was there( we'd also make sure when opening we'd copy the data and not just reference the data. Then we'd open the master project and import the desired tracks into that project. Many many times the desired import data did not follow and we'd wind up with blank clips!
Why? I'd then go back too the origin AAF I had just opened and everything was there then go back to the master project I had attempted too import that AAF data from and I'd see the same missing clips! Is this a known issue? At any rate this is indeed something that needs too be looked into
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 10-01-2014, 06:21 AM
Alécio Costa's Avatar
Alécio Costa Alécio Costa is offline
Default Re: 10.3.9 bug reports
What is not really cool is a last version for HD Accel with so many bugs.
Going back to 10.3.8? Hum...
Alécio Costa Studio
High-End E-Mastering & Music Production
www.aleciocosta.com
http://www.facebook.com/alecio.costa
PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 1,1 16GB RAM and Mac Pro 2,1 GB
Mastering Gear: Pendulum, Crane, Avalon, Great River, Sebatron, Sonnox, PSP, TC, Fab Filter.
Old 10-01-2014, 06:10 PM
Chief Technician's Avatar
Question Re: 10.3.9 bug reports
Is this an accurate summary of your process?
  1. Open AAF as if it were a Pro Tools session file (no import)
  2. Verify that opened AAF contains necessary elements
  3. Open a master Pro Tools session
  4. Import Session Data using AAF from step 1 into master Pro Tools session
  5. Clips that were imported from AAF appear as offline in master Pro Tools session
Old 10-02-2014, 07:24 AM
dtmprod dtmprod is offline
Does anyone know how to revert back to 10.3.8? Seemed like that version was much more stable than .9. I'm not able to get the 'uninstall' app to work. Does one have to manually remove prefs, etc?
Old 10-02-2014, 07:34 AM
Drew Mazurek's Avatar
Are you running Mavericks?
http://avid.force.com/pkb/articles/e...ools-Mavericks
www.drewmazurek.com
Old 10-02-2014, 12:53 PM
system info?
Jack
QAPLA!
Old 10-02-2014, 01:38 PM
Originally Posted by musicman691 View Post
system info?
I'm still on ML, 10.8.5…..
Old 10-03-2014, 03:37 AM
Are you using the uninstall from PT10.3.8? Actually the one from PT10.3.9 should work as well.
Jack
QAPLA!
Old 10-04-2014, 07:45 AM
I've been trying the one in my current folder, 10.3.9. Didn't think to try from 10.3.8 installer. C what happens there.
Old 10-09-2014, 02:56 AM
Cryos's Avatar
Yes. This is exactly what we were doing.
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Reports on OSX 10.4.3 LuisMota 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 11-09-2005 03:24 AM
Bug Reports araudio Pro Tools TDM Systems (Mac) 1 12-28-2004 09:50 PM
Reports on 6.7 here, please. Tubz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-14-2004 10:25 PM
wot no 10.2.8 reports? red_wedge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-23-2003 07:37 AM
PT6 OSX 001 bug reports go here---> Kling3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 34 02-24-2003 04:44 AM
