Old 03-05-2012, 10:22 PM
westonbueller westonbueller is offline
Question Getting a track's effect placed onto another track?!?!
Hello Pro Tools people,
I have recorded a vocal track, and after adding different amounts of chorus, reverb, and various plug in modifications I really enjoyed the way it sounded. the problem is, the track was just a practice take with no lyrics. When I record an actual good take with spot on pitch and lyrics, I cannot, for the life of me, get the old setup of plug in effects that I applied to the practice tracks on the good take. I have been trying so many combinations to get it to sound like the old track but it simply doesn't sound as good as the old one. I was wondering if there is a way to get the same exact vocal effect from the practice track placed onto the good take? Involving buses or anything?
Thanks,
Weston
Old 03-05-2012, 11:11 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Getting a track's effect placed onto another track?!?!
Navigate to the session folder and look in 'backups' folder. If there are a number of PT session files in there open each one (obviously one at a time) to check and see if your old session comes up.
There is a provision on each plugin to save current settings which can then be recalled for later use but that is not done automatically. Have a look at the Reference guide for instructions on how to do this for future use.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 03-05-2012, 11:25 PM
Tweakhead Tweakhead is offline
Duplicate your old track. (Select the track, then shift+option+D)
You can choose whether the copy will have the plug-ins, sends, routing etc..
Choose all except the main or alt playlists.
Copy the new vocal to this blank copy of your old track.
Old 03-05-2012, 11:47 PM
zedhed's Avatar
Assuming you are still in the same session right? I probably wrongly thought he had closed and was now in a new session. My bad.
HD 96I/O
Win 8.1 Pro
Old 03-06-2012, 07:04 AM
It really depends on exactly HOW you created your "perfect" sound in the first place. Were effects placed on the audio track? Did you use AUX sends to feed AUX tracks? Was it a combination of these tricks? Its certainly easy enough to import effects tracks from one session to another. You can also save settings on any plugin as a preset, so you can recall it anytime you use that plugin. Then there's the old trick of...taking notes (how analog)
Old 03-06-2012, 07:06 AM
imdrecordings imdrecordings is offline
Hold ALT+SHIFT, then click and drag
Old 03-06-2012, 07:44 AM
derFunkenstein derFunkenstein is offline
++ this is what I was going to write (assumign Windows, alt+drag each plugin also works). If it's in a different session, import session data first and import that track but not the audio.
PT11 2nd track automatically recording 1st track's audio problem KungFuRooster Pro Tools 11 9 08-18-2013 10:44 PM
Getting a track's effect placed onto another track?!?! westonbueller Tips & Tricks 4 03-31-2012 01:15 PM
Is there any way to automate an effect on and off on one track? rockguitarist1255 Pro Tools 10 5 12-23-2011 04:23 PM
How Do i Save Effect Into a Track? Floz313 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-20-2011 09:54 PM
PT9 - Embedding an effect on to a track steveejay_1 Windows 6 12-27-2010 05:58 AM
