Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 10-02-2011, 09:40 PM
Greg M Greg M is offline
Default Digi ASIO driver 64 bit
Does the Digi ASIO driver that installs with HD|Native work with 64-bit applications like Reason 6 or Vegas 64-bit?
Thanks,
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PTHDN 2018.4, HD Omni, HD I/O 16x16 .
Old 10-02-2011, 10:34 PM
Default Re: Digi ASIO driver 64 bit
64-bit Avid ASIO Driver for Native card is not currently supported.
Aaron Mulqueen - 001 HD Native
Old 10-07-2011, 08:38 PM
FRaNCo MuSiC FRaNCo MuSiC is offline
Thanks,
Greg
I have your motherboard and the same Ram and when you install Reason youu can install it for 64 and 32 bit. The Reason 6 32 bit will work fine as a standalone application or as rewire with pro tools. I have tested it and so far perfect!
Saludos
Franco
Old 10-08-2011, 06:18 AM
Franco, filo,
Thanks for the responses. I had already installed Reason 6 as 32 bit just as you suggest and it works fine. The lack of a 64 bit ASIO driver kind of leaves the upgrade from Reason 5 + Record 1.5 to Reason 6 without incentive. A couple of new Reason devices are nice, but the 64 bit performance is really what I wanted.
It is ineresting that Reason 6 64-bit setup did find an older version of a Digi002 ASIO FW driver and offered it up. I haven't had a Digi002 on this computer for a long time - I must have forgotten to uninstall it.
This is not really a big deal right now, but it does mean that Avid is going to have to embrace the 64 bit world here at some point or start losing functionality (like rewire) as others in the DAW world convert to 64 bit will eventually drop 32 bit support.
Thanks,
Greg
Old 10-08-2011, 11:58 AM
Greg, an Avid ASIO 64-bit driver will be released, it's just a matter of when. Ummm... even my M-Audio Venom offers a 64-bit ASIO driver, so does Eleven Rack.
Old 10-09-2011, 07:54 PM
Yes, that's true. I strongly believe that those drivers will come with Pro Tools 10. There are a couple of videos on YouTube where Avid shows some new functions and one of them is loading chunks of audio into the RAM (almost the entire audio from the session) and for that you need lots of RAM and 64 bit OS advantages.
Saludos
Old 10-12-2011, 05:28 AM
Well, now according to some rumors, the 64 bit will be not part of PT10. But the new features are still interesting.
Saludos
Old 10-12-2011, 08:46 PM
Now is that a 64-bit Pro Tools or a 64-bit ASIO Driver for Native HD systems?
Old 10-14-2011, 08:51 PM
Usually the Asio driver comes with the PT installer in the Windows case and my guess is it will come with a 64 bit PT version. Let's see what happens. Soon something new will come for sure, with PT and with it's drivers.
Saludos
Franco
Old 10-23-2011, 01:20 PM
Pro Tools 10 supports Avid ASIO Driver 64-bit for HD Native card.
DIGI ASIO Driver GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-02-2010 02:36 PM
DIGI ASIO Driver GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-02-2010 01:30 PM
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
Digi 002 ASIO driver..? FirstStep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-26-2003 06:50 PM
Digi 002 ASIO driver..? FirstStep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-26-2003 06:41 PM
