Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 01-01-2011, 08:46 PM
abnerd abnerd is offline
Exclamation Quickstart & Flash & OS X 10.6.5
I have not been able to get Pro Tools SE to work on my laptop.
I have an Intel MacBook that is about 2 years old.
Software installed as expected, but when I launch Pro Tools, the "Quick Start" window is blank (just a white window with no text or anything).
I have installed the latest version of Flash player from Adobe's website.... and still the Quick Start screen is white.
I have uninstalled & reinstalled Pro Tools SE & still have the same problem.
I even backed up my hard drive & did a clean install of OS X, Flash Player & Pro Tools.... same problem with the white Quick Start screen.
Is there a way to start the software WITHOUT the "Quick Start" screen?
I see no way to disable it.
Old 01-04-2011, 03:46 AM
Avid Product Design Avid Product Design is offline
Default Re: Quickstart & Flash & OS X 10.6.5
Please download and install the following patch:
http://www.m-audio.com/index.php?do=...5020442061ea89
This should resolve the problem that you are having with the Quick Start.
Product Designer
Old 01-04-2011, 09:11 AM
Thanks for your response.
I tried the patch but the problem still exists.
I have Flash 10.1.102.64 installed
Here is something interesting...
I went to the Adobe website to check my Flash settings.
http://www.macromedia.com/support/do...manager02.html
The interface works fine in Firefox, but not in Safari.
In Safari I can see the icons for each tab, but there is no text.
I am running Safari v 5.0.3 (6533.19.4)
Firefox v 3.6.13
I have Firefox set as my default browser (a preference in Safari)
Since it works in Firefox, but not Safari, could this be an Apple webkit issue?
Here is something else that is interesting.
I downloaded the Flash uninstaller & ran it (several times).
Flash is not deleted.... the Adobe site still says v 10.1.102.64 is installed.
Perhaps the Apple OS X 10.6.5 update places Flash in a different location than the Adobe installer?
Just a guess.
abnerd
Macbook 2.2GHz Intel Core 2 Duo
4GB RAM
OS X 10.6.5
Old 01-05-2011, 12:29 PM
Smile Re: Quickstart & Flash & OS X 10.6.5
PROBLEM SOLVED
Wiped my hard drive.
Reinstalled OSX 10.6
Updated to 10.6.2
Installed Protools SE
Everything works great.
Now I will update OSX until something breaks.
abnerd
4GB RAM
OS X 10.6.5
Old 10-05-2011, 08:37 AM
DavidInStLouis DavidInStLouis is offline
Ugh! You don't mean that I have to basically rebuild my entire system just to get this software to work!?
Old 10-07-2011, 10:56 AM
ttvanhalen ttvanhalen is offline
That's right, does anybody have a better solution? I can't run pro tools either because the 003 patch does not work for me I don't know why, perhaps is the same problem, if someone knows something please check my thread
Old 10-19-2012, 07:29 AM
nunsnmoses nunsnmoses is offline
Talking Partially Solved - Blank Screen
File : /Applications/Digidesign/Pro%20Tools/QuickStart/QuickStart.html
open in text editor - there are 4 entries for "Quickstart".
I have a case sensitive file system.[osx 10.8, mini]
I changed these to "QuickStart"
The interface partially loaded immediately.
So if anyone wants to pursue this - it might be the way .(fixing case sensitivity).
didnt get much further than that .. so pointers appreciated as well ..
OR CAN SOMEONE INSTALL IT ON A CASE INSENSITIVE FILE SYSTEM AND PLS LET ME KNOW
NOTE - Im on a mac mini 2009 2G, Osx 10.8.
Cheers
*** EDIT *** just found this -
http://m-audio.com/images/global/man...er%20Guide.pdf
"Do not choose the “Case-Sensitive” format option. Pro Tools will not operate properly with case-sensitive formatted drives."
Error occured while starting QuickStart tony_gro Pro Tools SE and Essential (Mac) 4 09-26-2011 02:00 PM
No sound past quickstart menu archangel4110 Pro Tools SE and Essential (Win) 3 03-01-2011 08:33 AM
Where is the START button -Visual quickstart guide GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-31-2004 10:32 AM
New Visual Quickstart Guide for PT6 Tito Ricci Arballo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-21-2003 09:35 PM
Q: Demo sessions for quickstart jbach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-19-2002 08:32 AM
