Old 10-08-2010, 10:16 PM
seeeker seeeker is offline
Default Installed Strike, activated license with iLok> no Strike.
Ok. I've jumped through all the hoops, done the iLok thing, my license is activated on both Digidesign and my iLok key. My question, so where is Strike?
I open Pro Tools, look through all the plug-ins in the inserts, and there's nothing there. Where is it supposed to be?
Old 10-08-2010, 10:36 PM
Top Jimmy's Avatar
Default Re: Installed Strike, activated license with iLok> no Strike.
It sounds like while you have the authorization to run Strike, you have yet to install it. Do you have an installation disk? Do you have links to the installer? The iLok auth is just the key that lets you use the plugin.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 10-09-2010, 02:41 AM
stonehenge stonehenge is offline
if it is installed, make sure you are trying to insert it on a stereo aux or instrument track - not mono.
Old 10-17-2010, 04:21 PM
Ok, got it - it was the stereo aux input for the track. I thought maybe even if the track was not the right type, it would have still shown up in the inserts pull-downs, but apparently not.
I'm a total newbie, and it didn't say anything at all about this in the supporting material. Apparently they think is too obvious to mention.
Thank you very much.
License transferrred to my ilok - Strike 1.5 (drum plugin). g_penton@yahoo.com Windows 1 11-19-2013 07:54 AM
Strike installed but won't launch in PT 10 Mac Walter macOS 2 11-04-2011 05:52 AM
Strike installed but won't launch in PT 10 Mac Walter Pro Tools 10 4 11-04-2011 05:51 AM
Strike 1.0 license removed from ilok rical Virtual Instruments 1 03-04-2011 07:50 AM
Strike License only? RaySoul The Drum Room 4 01-05-2010 01:20 PM
