Old 04-20-2010, 09:37 AM
cmedina cmedina is offline
Default Upgraded to PTIEP from Strike, do I need to uninstall Strike 1.0.2 first?
Hi All,
I just upgraded from Strike 1.0.2 to the new PTIEP. It's taking forever to download, I need both platforms since I work on a desktop PC and on-the-go on a Mac. Just finished my PC downloads, uninstalled Strike 1.0.2 and tried to install Strike 1.5 which apparently went successfully (installed all Contents as well). However when I tried to use the plugin, PT8.0.3 hangs. The new Hybrid, Transfuser and Velvet all work, it's just Strike.
Should I not have uninstalled Strike 1.0.2 first? I'm asking because later today I will have finished downloading the Mac versions and I want to make sure I don't have the same issue with Strike. If I should leave the old version on I'd like to know prior to install.
Or could it be that the install just didn't go well and I should uninstall/reinstall my Windows Strike plugin again?
Thanks in advance!
Problem with Strike 1.5-Pro tools 10 wants to move Strike.dpm to unused folder. We live forever Virtual Instruments 55 09-17-2012 06:02 PM
Just Upgraded to Strike 1.5, but Authorization not Recognized mix house la macOS 1 01-22-2012 02:29 PM
PTIEP Strike filosofem Virtual Instruments 20 03-31-2010 03:10 PM
DAE error #7400 PC (STRIKE only)????? STRIKE WONT LOAD!! TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-21-2008 08:19 PM
Upgraded To 7.3-STRIKE & MP-Toolkit Updates Here! Light Wing Virtual Instruments 3 12-12-2006 05:31 PM
