Old 12-28-2007, 01:12 AM
Krumbz Krumbz is offline
Default Digi Tech Support: Control|24 Clicking Noise on Power On
Hey guys... happy post-holidays!
Long story short.
Went to turn on my Control|24 worksurface yesterday and instead of doing the normal Fader cycling process... it just made a clicking noise over and over... with the lights flickering so fast that you could barely even notice them blinking at all.
My questions are these below.
Is this a Power Supply issue where the PSU needs to be removed and replaced?
Or
Do I just simply need to clean the connectors?
Or
Is it a connection issue where the connectors aren't touching so they need to be "reseated"?
The reason I'm not sure is because I think if the Power Supply Unit (PSU) really did go "bad" the unit shouldn't turn on at all right?
So I'm inclined to believe that its either a cleaning issue or a connection issue.
From your guys knowledge... which of these three scenarios seems the most likely... given my description of what went wrong?
I know that the Power Supply is usually the culprit with issues such as the "All Lit Up" thing - which I don't have happening. But would the Power Supply just make the unit click repeatedly? Doesn't seem likely imo.
Thanx for your time! My girl purchased Apples 30" monitor for me for X-mas so I'm extremely eager to get back to work asap!
Later
Krumbz
PS Yes I know... I love her... believe me!
Old 12-29-2007, 06:35 AM
Echo studios Echo studios is offline
Default Re: Digi Tech Support: Control|24 Clicking Noise on Power On
Sounds to me like connector's issues: such as they're getting loose enough inside the PSU by ibrations or movements..or in the worst scenario the PSU itself to be replaced.
I'm about to replace each and every single Molex connector from the PSU with new Crimp Terminals (with contact in three sides, with firm, tight grip) and see if the All lit up issues and hassles goes away once and for all.
Because every time i stumble on such glitches, the only workaround is to just re-seat a few connectors (mainly the TB4 for the scribble strip) and the problems goes away for a long period of time ...then it comes back after !
I'll let all users know if this is the real fix in a matter of weeks..
Good luck!
Dan
PT HDX2 / Ultimate / D-Command ES 24 w/ edit pack
MP Dual 3.66mhz ( 6-Cores) / 32GB / SDD 8TB
OSX Sierra 10.12
Dan Desilets
Mix/Mastering Engineer, Guitarist, Composer
New Website live @ www.sublimesoundstudios.com
Old 12-29-2007, 02:51 PM
Well I went halfway around the world in search of Deoxit. Found it. Opened the back panel, removed any excess glue hanging on the board with some needle nose pliers, disconnected the white connectors, cleaned all the connector rods with Deoxit, twice, replaced the white connectors, pushed everything back in and voila! It works!
I'm still unsure whether or not it the connectors needed to be "cleaned" or just "reseated" but I did both and everything worked out. I kinda knew that it wasn't the Power Supply Unit simply because it still turned on somewhat.
I should be okay for awhile. If it happens again... I'll clean them again with Deoxit regular then apply Deoxit Gold to protect them. May even use a little heated glue gun to glue the white connectors in place so they don't vibrate and disconnect.
Echo Studios thanx for your reply bro!
Krumbz
Old 12-30-2007, 07:03 AM
No problem..
But be aware that you'll need more than glue or just De-oxit / Progold...
I have both and the problem keeps rising again! Just wait a few weeks and then it'll come back and maybe right in front of clients also! Like it did here..
The connectors are way too loose and they'll move again and again trust me i spent 3 years living with this problem. Digi *really* should have made all these connectors with Trifurcon Crimp terminals with 3 contact - firm connection - instead of loose when you connect them.
Even had the C24 repaired twice by a Digi authorized center without any luck They figured out the same thing as me....Connections...
I'll post the recipe right here when i will be SURE that it is going to get FIXED once and for all.
Thanks!
OSX Sierra 10.12
Dan Desilets
Old 01-11-2008, 12:45 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Dan
So what's up at Echo?
Have you done this yet?
I assume you've seen the thread posted with actual Part Numbers for crimps & molexes?
Is this the stuff????
How'd it work???
Tell me! Tell me!
NOW!!!!!!!!
Haaaaaaaaaa
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 01-11-2008, 07:26 PM
fasttraxx fasttraxx is offline
Echo,
Are you talkling about the Control 24 or the newer C24?
Thanks and God Bless!
Y.B.I.C.
Bill
Old 01-14-2008, 05:48 AM
Well here's the results (applies only for the older Control24).
So far so good.
Been two weeks now running the Control24 almost 24/24 and using it against heavy sessions. No scribble strip problems, no flashing leds and monitoring problems.
But i'm not 100% convinced, if i manage to pass 6 months like that then i'll definitely have to say that i've fixed it.
I replaced every molex connector you can found inside the Control24 with new crimp terminals anbd cleaned everything at both ends. Now they are secured and tight cannot move at all ! So if something happens it coule be vibration anymore.
YOu can find the fix here originally posed by another DUC user:
here's the fix:
Trifurcon™ Crimp Terminal 6838, 18-20 AWG, Bag, Phosphor Bronze Tin (Sn)
molex part number 08-52-0113
trifucon crimp terminal -Mouser Part #: 538-08-52-0113
crimp terminal housing-
2 circuits- 538-09-50-3021
3- 538-09-50-3031
4- 538-09-50-3041
5- 538-09-50-3051
8- 538-09-50-3081
these are molex pins that grip the post so that it will have contact on 3 sides. I use these on several different machines and found they work on the C24 as well.
Studio Troll
I'll keep you posted if something happen in the meantime,
Good luck all,
OSX Sierra 10.12
Dan Desilets
So far so good.
I replaced every molex connector you can found inside the Control24 with new crimp terminals and cleaned everything at both ends. Now they are secured and tight they cannot move at all ! So if something happens it could NOT be vibration anymore.
here's the fix:
3- 538-09-50-3031
4- 538-09-50-3041
5- 538-09-50-3051
8- 538-09-50-3081
Studio Troll
Good luck all,
OSX Sierra 10.12
Dan Desilets
Old 01-24-2008, 06:07 PM
When you're right you're RIGHT! This issue is back again!
I'm very tempted to try your method but it really seems pretty complicated and somewhat risky.
So I would have to remove those old white connectors and replace them with these new Molex ones? So how do I go about that in a safe manner? Do I have to do some sort of wire crimping? Also theres little to NO room to work with as all I have is that small rear panel removed and it only comes out so far.
Any input would be very helpful!
Thanx again Echo!
Krumbz
Old 01-24-2008, 06:10 PM
By the way... where's Digi Tech Support??? It's been months and they haven't even replied.
I'll be honest... between having no ADC and my Control 24 doing this VERY annoying and inconvenient connection thing... plus Apples Logic dropping their price to DIRT CHEAP... Logic is looking rather handsome right now.
Digi 002 Workstation refuses to power up, just makes a repeating clicking noise Stormshadow2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-05-2012 03:33 PM
Digi Tech Support Chill Pro Tools TDM Systems (Mac) 3 03-19-2008 06:56 AM
Digi 003 Rack clicking noise during power up thefremonts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-13-2007 09:08 AM
Digi 002 makes clicking noise and craps out. Help grasshopper47 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-18-2005 02:31 PM
As requested by Tech Support, Pro Control 'wish list' Jules ProControl, Control|24, Command|8 46 10-31-2000 03:49 AM
