Recorded Audio Not in Time bug Audio always early
This is a real problem we have been dealing with here at our pro studio for over 2 years!!! Digidesign has been working with us for over 6 months to solve this problem. We have tried everything, except new hardware. No luck yet. It happens on 3 independent HD3 accel systems, on G5s and G4s. All at random, sometime weeks go by and it's fine, other times it's 5 times in one day. It's way too complicated to describe in an email, but it would help out if you could report this problem to digi ASAP to let them know we are not alone!!!!!! I know there was one user in PC land that has recently discovered this bug. ANYONE ELSE ON MAC HD HAVE THIS?? David Piefer is our contact. Please speak out!
No hardware delay compensation. No delay comp active ( while tracking) No plugs Internal Clock Correct software settings G4s and G5s Os9 or OS 10 (all point versions) from protools 6 to 6.9. It's still with us. The syptoms: -audio recorded sounds fine while recording -once waveform is redrawn, audio is always EARLY (to the left, between 50 and 250 ms), but region start time is original, there is also usually a snip-it of audio at the very end of the recorded region. It's really fun when it happen to one side of a stereo recording. There is one work around for the bug. Here it is: Shuffle delay comp engine on/off BEFORE you start recording on your session. This seems to prevent it from occuring. This will also FIX the problem once it has occured in a session. It seems you need to do this with every session you open BEFORE you start to record. |
Re: Recorded Audio Not in Time bug Audio always early
There's been a thread going on this over the last several weeks. You're definitely not alone. Thread's been silent for a little while -- hopefully that means it's being investigated. A number of people described the exact problem you're describing (including myself) on a mac. Pretty scary.
OS 10.3.8 PT 6.9 Dual G4 MDD 1.25GHz HD3 192 i/o
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
Still happening here on a G4 , HD 3 accel. Really upset clients again. HELP DIGI!
Dual gig- 6.9.1cs3 |
Happens here also.
G4 duel 4.2 2 drives one with OS 10.3. one with Tiger 10.4.2 (Happens on both) Pro Tools 6.9.1cs3 HD4 |
I know that Digidesign is working on this issue to reproduce it "in house". Just wondering, is everyone that is seeing this problem running an HD3 rig? Anyone tried pulling out their HD Accel or Process cards to run an HD1 or HD2 system and see if the problem continues? That might help Digi figure out what's going on. Is your HD3 with Process cards or Accel?
Hi HAWKEYE. I am on the phone with Kevin at DIGI right now. Want to let you know that, no, you are not the only one who has this problem. I had a session ruined last night. Client was VERY upset. I will try the "toggle ADC" workaround, but that's not the only problem I am having.
Whenever I "option R" a region by multiple measures, by the end of the song, the region DRIFTS off the grid. Funny thing is, when I did it at 120BPM, it all locks. But when the tempo moves up, either in CONDUCTOR or MANUAL mode, by the end of the song, it's off the grid. KEVIN at DIGI is now trying to replicate the problem. He did, and doesn't know what's causing it or how to fix the problem. Apparently, he will "add it to the list" of problems to be addressed. For know, I will have to copy and duplicate regions by hand multiple times to ensure "grid integrity". If anyone else knows of this problem, please reply. |
KEVIN just called back and told me that the fix for my other problem is to specify the track to be TICK based, and not SAMPLE based because, mathematically, it's not accurate enough. Haven't checked to see if it works yet, but, THANKS to Kevin for checking that out!
Recorded audio placed 40ms too early | peteage | FireWire & USB Audio Interfaces (Win) | 3 | 09-11-2013 08:05 PM |
Recorded audio playing back too early | jonwade92 | macOS | 3 | 04-15-2013 01:01 PM |
Recorded Audio not in time | ebrowne | Pro Tools 10 | 3 | 09-15-2012 09:04 AM |
Recorded audio too early in relation to backing track | MagDee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-23-2011 04:23 PM |
time-shift between recorded audio and midi | indigo | Pro Tools TDM Systems (Mac) | 0 | 09-21-2000 03:35 PM |
