Old 04-28-2016, 09:44 PM
modulo2008 modulo2008 is offline
Default Protools 12 HD very slow response about Edit Window
HELLO.
I'm using Protools HD 12.4 & 12.5.
but it's too slow operate about region moving & paste & making fade & automation curve writing.
I tried to test some OS (10.9.5 & 10.10.5 test) & versions (12.4 & 12.5).
but it's same problem.
The problem happens when I appear plugin list with many plugin.
Organize Plug-In Menus by "Categorie & Manufacturer" is too slow.
bit "Flat" is no problem (works fine)
I tried beam sync off & disable spotlight. but same problem.
Protools HD10 is ok with same machine & setting.
Let me know solve this problem....
Mac STUDIO 24 core M2 Ultra 2023 (128G Ram) / OS 14.4
Pro Tools HDX2 & UAD-2 (20Core)
Old 05-29-2016, 07:25 AM
albanfurtuna's Avatar
albanfurtuna albanfurtuna is offline
Default Re: Protools 12 HD very slow response about Edit Window
I have the same problem,I have tried from Montanin Lion to el Capitan the same problem.I suspect this may be a problem of graphic card because if you do hide the track and leave one or two tracks this bug does not occur,or if hide the insert,send,instrument from edit window again this bug does not occur.
I have an mid 2010 mac pro
2 x 2,4 GHz Quad-Core Intel Xeon
32 GB 1066 MHz DDR3 ECC
ATI Radeon HD 5770 1024 MB
I will soon try some graphic cards and whether the problem is resolved will write to you directly.
And please excuse me for my bad english
AF
Old 05-31-2016, 11:29 PM
I tried to install another graphic card with AMD R9 280X 3GB.
http://www.pro-tools-expert.com/home...-in-my-mac-pro
However, It can not be solved problem.
(basic OS speed & performance is faster than before, but protools GUI is very slow yet.) I thought that this problem has nothing to do with graphic performance.
I reported this problem in avid & get answer "investigate as Formal escalation with this case"
I thought that it's bug since 64bit format Protools 11 with many plug-ins installing case.
By the way I test to install default + waves complete + UAD-2 only with clean install Yosemite. But it's same here.
Threfore I'll wait for answer avid's reply.
Old 07-03-2016, 08:35 PM
stereomixxxer stereomixxxer is offline
I have the exact same problem, and actually had to slow down my editing to adapt to the lag in PT. Pro Tools 10 flew without any lag, but from PT 11 and on, there was definitely a lag I noticed right away in editing and the overall responsiveness.
Any fixes yet?
I tried switching out video cards, ran different operating systems, but no dice.
Old 07-03-2016, 09:00 PM
Any fixes yet?
not yet with new PT12.5.2.... (best performance with PT12.4. but slow anyway)
How many plugins do you install?
But you can solve if you reduce plugins. (only avid)
Old 07-19-2016, 08:21 PM
I have quite a bit of plugins installed.. roughly 90. I just tried placing all of my plugins in the unused folder and restarted PT... still slow. Doesn't affect the performance at all.
Old 07-22-2016, 05:53 AM
biffrov biffrov is offline
I have the same problem. It's EXTREMELY frustrating.
Tried:
1. All optimizations.
2. Different harddrives (and optimizing them)
3. I have no floppy.
4. Messing with disk cache.
It doesn't seem to be a graphics problems since _everything_ in PT freezes for 3-5 second if do a cut/fade/slide the region.
The only thing that solves it is when I consolidate all the cuts. And that isn't really an option.
Windows 7 Ultimate 64bit
Intel I7 3,4 ghz
16gig ram
PT12 has been all problems for me since I bought it.
Old 09-27-2016, 06:11 AM
ZanderM ZanderM is offline
I have the same issues. I did everything as listed by avid. CPU is under 40% and memory only 10%. I tried removing unsupported plugins (Native Instruments/Audio Ease Altiverb) from pro tools plugins folder with no luck.
Old 09-28-2016, 10:04 AM
btreim btreim is offline
I am having the same issues with HD 12.5.2. The steps posted above haven't changed anything on my system.
2x 2.4Ghz Quad Core Intel Xeon
OSX 10.9.5
32 GB Ram
Old 09-28-2016, 10:13 AM
YYR123's Avatar
YYR123 YYR123 is offline
HELLO.
I tried beam sync off & disable spotlight. but same problem..
A video showing the problem would be nice......
I don't see these issues....running 12.5.1 HDN and Mac 10.10.5
Daniel
ProTools 10 Slow Response. Won't even play 10 drum tracks without Stopping! bigfootjim Pro Tools 10 15 04-12-2014 08:03 AM
ProTools Edit Window Disappears With Soundminer Spot to Timeline chadjhughes macOS 1 02-25-2014 06:51 AM
Frozen level meters and super slow window response sitonka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-18-2006 12:52 PM
Protools Edit Window Cursor on OSX grasshopper47 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-31-2004 02:39 PM
Edit window-slow refreshing? JACEK GAWLOWSKI Pro Tools TDM Systems (Mac) 4 10-06-1999 02:26 AM
