Old 04-04-2005, 01:32 PM
mach-1 mach-1 is offline
Default help using DFH2 samples with sound replacer plugin
I cannot get sound replacer to find any of the samples from the East West DFH2.
There is no literature from East West.
I have copied the library folder on to my computer hard drive.
Does anyone have a clue how to get the samples in WAV or AIFF format so the sound replacer plugin can locate them? I am just seeing a bunch of nothing at the moment.
I am extrememly new to using DFH and could really use a hand.
My goal: beef up snare and Kick sounds with some samples.
Thanks
Mach-1
Dual 2.5Ghz Macintosh G5
OSX 10.3.8
4.0GB RAM
External Firewire 160GB Glyph HD
Old 04-04-2005, 08:06 PM
Flamethrower Flamethrower is offline
Default Re: help using DFH2 samples with sound replacer plugin
I'm not too sure about DFH since I don't own it, but I do own East West/QL Symphonic Orchestra. The raw samples that make up an instrument are imbedded into one giant file that show up as an ".nks" file in Finder. Not a .wav or .aif to be found.
What comes to mind is to program a MIDI track to play all the hits you want (not overlapping), record them onto an audio track, slice them up into individual hits and then bounce those hits as aiff files. Kind of time-consuming, but I know of no other way.
PowerBook G4 1.25 gHz with 2GB RAM, OSX 10.3.7,
PTLE 6.7 with MBox, 2 LaCie d2 FW800 drives, Reason 2.5, Ableton Live 4, Waves Gold Bundle
Drum samples for Sound Replacer Blackers The Drum Room 9 02-12-2018 05:06 PM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
Need samples for Sound Replacer tommyj1112 General Discussion 2 09-08-2004 03:12 AM
How do i load samples into sound replacer Kevin P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-29-2003 05:20 AM
Sound Replacer Drum Samples XCLAIM Tips & Tricks 27 03-02-2001 12:26 AM
