Stuck MIDI Notes
Hey guys. I wanted to start messing around with MIDI instruments in Pro Tools (previously I've only used it for postproduction audio for film). I hooked up my CASIO CDP-100 keyboard via an old, cheap MIDI-to-USB cable I've had forever.
Here's what's driving me crazy: when I put an instrument track into record ready, and start playing the keyboard, the instrument will cut out every few seconds, either leaving a note hanging or refusing to play anything at all. Then, after a few more seconds, it will come back. Now, the whole time, I can see the levels responding to the keys I'm hitting in the Instruments panel for the track. The really strange thing is that if I actually start recording, everything works totally fine; the problem goes away completely. I've tried this mostly with the AIR instruments that come with Pro Tools, although I also installed a free synthesizer plugin, and it's doing the same thing. I also opened up MuseScore, and that program seems to have no problem with the MIDI connection at all. Help! Specs: Alienware Alpha R2 with Windows 10 CASIO CDP-100 keyboard Pro Tools 12, fully updated, all plugins fully updated |
Re: Stuck MIDI Notes
Couple of things to try/look at:
try a new MIDI to USB converter make sure you have turned off ALL power savings measures in Windows Control Panel especially for the USB ports |
Replace the cable. Use a powered USB hub. Reinstall drivers for midi input/keyboard. just some stuff to try.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Stuck MIDI Notes! | delgadil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 08-07-2007 03:56 PM |
MIDI notes get stuck | dcf16 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-23-2007 06:54 AM |
Stuck Midi Notes | pmh3r | Pro Tools TDM Systems (Mac) | 11 | 11-10-2005 11:55 AM |
Stuck MIDI Notes....Anyone See This? | tomhartman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-04-2005 10:43 AM |
Stuck Midi Notes With MTP | CHRIS AIKEN | Pro Tools TDM Systems (Mac) | 9 | 03-28-2005 10:21 AM |
