Old 01-28-2018, 04:39 AM
GCScott GCScott is offline
Default Cycle through Auto-expand plugs
Hi guys,
Running S6 software 3.7.
I'm sure there is/was a was to cycle through plugins in an auto expand zone on a knob module.
Similar to double tapping a plug on the processing module to cycle through, is there a way to do so on the attentioned track's auto expand?
For example, I attention an audio track with 4 plugins on with the default being 'auto expand insert 1', then, by holding ctrl+pressing attention again I can cycle through inserts in the order they are placed on the track. Or perhaps a way to just reach the 'backup function'
Thanks in advance.
Old 01-29-2018, 01:54 PM
creativecontrol's Avatar
Default Re: Cycle through Auto-expand plugs
Agreed 100%
There is currently no way to cycle the Attentioned Knob zones on the surface for DYN or EQ. I believe we have discussed using some of the lowest row BACK buttons on the knob module to accomplish this task.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-30-2018, 05:33 AM
innenhofstudios innenhofstudios is offline
i have to switch auto-expand permanetly off because it overlays the pan display on the display module.
Btw Auto-Expand is permanetly enabeld here. if always have to un-able it as soon i open an other session...
www.innenhofstudios.at
Old 01-31-2018, 09:07 AM
Can you elaborate a little more on your issue please? Do I understand correctly that you have Attention Knob and Attention Fader module zones in a bucket with a display module which is not a master meter module and you are getting odd behaviors on the display module? Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
HDX end-of-cycle? basehead617 Pro Tools HDX & HD Native Systems (Mac) 49 04-03-2020 10:56 AM
DIGI - US2400 - PT8LE - WinXP - Plugs cause 2400 to cycle Table Syrup Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-26-2010 05:56 AM
Do Waves plugs auto-convert RTAS to TDM? jahtao Post - Surround - Video 5 01-14-2010 08:41 AM
command+ctrl+opt+click to auto enable parameter not working on AIR plugs crizdee Pro Tools TDM Systems (Mac) 10 03-29-2009 11:31 AM
60 cycle hum indieo General Discussion 3 10-04-2000 09:15 AM
