Mix Window not recalling with session
PT Ultimate 2023.3.0
Mac OS 13.2.1 When I open a session, the mixer window doesn't get recalled to the correct (2nd) display. Instead it sits behind the edit window on the 1st display until I relocated it manually. It does this every time on every session. Is there a preference will make it recall correctly or is this a bug with 13.2.1? |
Re: Mix Window not recalling with session
is it the full height of the screen ?
try shortening the height of the Mix Window to about 20 pixels from the bottom of the screen. save. reopen. |
Not sure if it has anything to do with it, but have you tried disabling (or enabling, don't remember which) "Displays have separate Spaces" under "Desktop & Dock" in MacOS System Settings?
Stein Tore
Stein Tore Sønsteli Pro Tools Ultimate 2023.12 (HDX-2), Mac Studio M1 Max, MTRX Studio, Avid I/O's, S1 + Dock |
I've given up on PT and macOS windows/spaces/displays recall long ago. I've resigned to restoring window positions manually each time I open a session.
I think it's a question of PT development not keeping up with macOS changes.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
If you have the edit on one display and mix on the other ----if you save manually just shy of full screen OR ( If you hold "Option" and then click the green button upper left) it will resize almost full but leaving the header bar and dock displayed),, and then save and close , it will open with edit on one display and mix on the other
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... Last edited by K Roche; 06-01-2023 at 07:07 AM. |
Thanks for the replies everyone. I don't have any PT windows in full screen, always a tiny bit shy of each edge.
Unfortunately not, thanks though! |
Interestingly enough, the video window and plugin GUIs retain their position. Seems that the only one affected is the mixer window, odd.
FWIW, Moom will restore all your window positions with a keystroke or automatically:
https://manytricks.com/moom/
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Looks like it's just my 3rd display (a sony TV) that's affected. Everything recalls correctly to the first 2 displays (Benq monitors). Could be the HDMI splitter...will investigate more.
Auto-recalling of Eucon channel fader assignments when launching a PT Session | antonis | Avid S1, S3, Dock and Control App | 3 | 02-23-2023 10:14 AM |
Show Tracks in Edit Window When Recalling a Layout on S6 | colinato | Avid S4/S6 | 5 | 08-10-2022 07:05 AM |
PT not recalling filtered take views when resuming a session | take77 | Pro Tools 12 | 0 | 10-17-2015 01:51 AM |
Recalling Window Configurations - Does it work? | Sonic Nomad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-21-2007 02:57 AM |
Recalling an old session, newer version of plugins | RBaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-07-2006 08:23 PM |
