Old 03-09-2004, 12:53 PM
The Cobbler The Cobbler is offline
Default \"Channel Matrix\" acting up
Lately our channel matrix section of our procontrol main unit has been acting intermitantly. We typically run the channel matrix in view mode and for a year we have not had any problems.
Now, the matrix keys will simply stop functioning during a session. Jogging the unit in the ethernet controllers page under the peripherals menu helps temporarily, as does trashing the digiprefs or resetting the firmware. But the problem comes back within a few hours.
Is there anything else I can try (short of reinstalling ProTools)? The fact that we can "fix" it by jogging software settings makes me think that this is not a hardware problem, but I can't be sure. Any suggestions?
Old 04-22-2004, 06:37 AM
Default Re: \"Channel Matrix\" acting up
I still haven't been able to figure this out. Has anyone else even seen this (or something similar).
I have to disable the ethernet controllers and re-assign them at least once a day.
Old 08-12-2004, 11:20 AM
This problem seems to be getting worse. It used to creep up only after closing one session and opening another. Recently it's been happening throughout the course of a session. We can still get functionality back by unassigning the main unit and then reassigning it, but I end up going through the motions 5 or 6 times a day. I've tried reseting the firmware with no effect.
Anyone?
Old 08-13-2004, 05:07 PM
Mano Mano is offline
I have a problem that seems alike...
Whenever I work on smaller projects ( 16 fader or less) I disable my two outer faderpacks.
When I do this my channelmatrix becomes dead. I can't select,enable,disable or edit any group or channel.
The only thing thast solves the problem is reloading the session.
It's a 6.4 (whateverCS)problem
Old 09-07-2004, 03:38 PM
Let's keep this topic on top of the list
We'll wake them up ( hopefully...)
Old 09-23-2004, 02:21 PM
AND DIGIDESIGN STILL KEEPS QUIET...... no reaction...no response...the phone is dead...the procontrol seems obsolete...
Digi...please fix the lost of channel Matrix in PT8 vudoo ProControl, Control|24, Command|8 33 12-12-2009 02:46 AM
Channel matrix fixed in 8 Pete Gates ProControl, Control|24, Command|8 4 11-12-2009 03:32 PM
Anyone here using PT8 and Procontrol with no loss of Channel Matrix ?? vudoo Pro Tools TDM Systems (Win) 10 04-24-2009 07:31 PM
Loss of Channel Matrix in PT8 maxtn ProControl, Control|24, Command|8 8 03-28-2009 09:14 AM
Channel Matrix on Pro Control Armando Pro Tools TDM Systems (Mac) 7 07-12-2002 06:54 AM
