Old 05-28-2001, 01:39 PM
chester chester is offline
Default Can you use Control 24 with Emagic Logic Audio?
The MIDI capabilities in Pro Tools seem pretty limited (no score view) so I'm hoping to still use Logic Audio for MIDI composition. Unfortunately, it seems I need to route my modules back into the submixer or a line input on the Control 24 to monitor them. And I don't have any luck monitoring because the Control 24 is offline. Anybody here in the same situation? I'm going to contact Emagic tomorrow, but I thought I would post here first.
Thanks!
Old 05-28-2001, 01:51 PM
Default Re: Can you use Control 24 with Emagic Logic Audio?
One possibility, I'm realizing is just to slave Logic Audio to Pro Tools via MTC on a permanent basis. I used to only do that to transfer tracks from MIDI to audio to mix in PT. I think I might have to do that all the time. I'm open to any other ideas though...let me know...
Old 06-01-2001, 05:23 PM
tech_head tech_head is offline
Unless Digi get's off it's arse (dream on)
and releases an API for PC or Control 24,
forget it.
My one pet peeve about the PC that I own is
that I can only use it with ProTools.
tech
Old 06-06-2001, 05:41 AM
Rafael VA Rafael VA is offline
Yep indeed, I use MTC also to link Logic with Protools. When I'm composing in Logic (for midi-related-gear) I put on the mtc to sync the both. Then I record in ProTools to use the edit- and plug-power. Best of both worlds. And I know a lot of guys who are doing the same now.
Emagic Logic Control with Pro Tools 001tony Pro Tools M-Powered (Win) 0 01-14-2011 02:18 PM
002 -> Emagic Logic Pro as control surface? Hans Arvid MIDI 0 08-31-2004 07:12 AM
control 24 and emagic logic audio uli b ICON & C|24 4 01-19-2003 11:25 AM
Will Digi002 be Compatible with Apple, oops, I Mean Emagic Logic Audio Platinum? electrobank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-20-2002 02:21 AM
DIGI001 and Logic Audio - DIGIDESIGN & Emagic, PLEASE CLARIFY johnwesleybarker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-30-2001 12:28 AM
