Old 11-06-2015, 03:03 PM
HMA HMA is offline
Default Delay compensation ignored on commit?
Does the timing of audio remain the same also on heavy delay compensation cases like committing an vocal track to WavesTune plugin.
A quick test shows that waveform moves along the timeline after commit. Or am I doing something wrong?
Old 11-06-2015, 03:11 PM
Wall2Wall Wall2Wall is offline
Default Re: Delay compensation ignored on commit?
that would be unfortunate.
Old 11-06-2015, 03:19 PM
HMA HMA is offline
If I put heavy plugins on the same vocal track, like waves tune lite, debreath and cla vocals , I can expect odd behaviour on committing the track. For example after committing to waves lite tune plugin cla vocals plugin dissappeared on the new committed *.cm track. And the audio was moved several samples earlier compared to the original ?????
But one possible reason might be that the delay compensation value is on dark red...on an instable condition i suppose.
Old 11-06-2015, 03:32 PM
dankin dankin is offline
No issues with Slate Trigger. Wonder if it's something to do with those plugins?
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII
Old 11-06-2015, 03:49 PM
HMA HMA is offline
It is not the first time that long delay look ahead plugins are causing trouble. Debreath is one of those. Hope that in general there is no problem issue with committing to smaller latency plugins.
Old 11-06-2015, 04:24 PM
HMA HMA is offline
I had a lot of muted and heavy duty plugins in the track when problem appeared. After reducing the plugins even waves debreath committed right without problems waveforms in the same spot in the timeline as the original ones.
Old 11-06-2015, 04:32 PM
connor@@vid's Avatar
connor@@vid connor@@vid is offline
We did a lot of validation in this area to make sure that things appear where they should. If the delay comp value is dark red it means it is beyond the maximum available amount of delay compensation so inaccurate compensation is expected. If you continue to have problems in normal conditions we'll need to get sessions (no audio needed) and attempt to reproduce issues internally. Thanks!
Old 11-06-2015, 05:09 PM
HMA HMA is offline
Picture attached
Old 11-06-2015, 05:26 PM
Unfortunately this picture doesn't tell enough story to know what's at play. Whats the delay on the track you're committing. what commit options did you choose? Is the 0.002 second offset the specific problem or are there other issues? Thanks!
Old 11-06-2015, 05:31 PM
HMA HMA is offline
Yes, the offset is around 2 ms. Same can be measured on the peaks that can be seen in the waveform. I did full track committment. The original can be seen above and the committed below. You can also see the plugins in the upper one. I had consolidate option on. In the track region start there is no offset, only in the waveform.
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 03:35 PM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
To Commit or not to Commit, that is the question. georgejw22 Pro Tools 10 10 12-20-2011 05:30 AM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-05-2010 11:00 PM
Delay Compensation - Delay Monitoring when REC Howardk Pro Tools TDM Systems (Mac) 2 06-18-2006 08:59 PM
