Using eleven rack with another interface
So I've tried everything I could find online and I stall can't make my eleven rack work with my Scarlett 18i8 on pro tools. The ER works fine on it's own, however I don't wanna be switching interfaces everytime I need to record something different.
I hooked up the ER to my 18i8 through the S/PDIF. The ER Clock is set to external. On the Mix control for the Scarlett I set the S/PDIF inputs for left and right. I've tried getting sound from the ER as an insert>io>spdif but the plug in becomes inactive as soon as I set it up giving the message 'The insert was made inactive because the output path is already in use' I've also tried setting the input of the audio track to SPDIF. I don't know what I'm doing wrong and I could use some help :) |
Re: Using eleven rack with another interface
Page 69 or so of the user manual. Make sure your rig output is set to digital
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob Squaw Creek Road Studio Pro Tools Ultimate (2024.3)| Pro Tools Carbon | Sibelius Ultimate (2024.3) | 3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 | Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X | Lenovo i7 ThinkPad | Win 7 Professional | Avid 003 + Rack | |
What interface is set as your main interface in Pro Tools?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I'm sorry to be replying to this so late :/
I'm using a Focusrite Scarlett 18i8 as my main interface. |
I've used the Eleven Rack as a secondary interface on a system with a 003 as the main interface, and am using it as a secondary interface on a Mac Pro with a 96 I/O (HD Accel). Allows me to easily select different sources within PT. Just need to make sure it's set up correctly, so check out Benoni's video at https://youtu.be/W0DRUGqfQ8o for an overview.
Eleven Rack as Interface | Dopamine | macOS | 10 | 02-02-2013 11:35 PM |
Eleven Rack As Main Interface | h2os | Eleven Rack | 4 | 10-17-2012 04:20 PM |
Eleven rack with another interface ? | oplatner | Eleven Rack | 11 | 05-30-2012 07:33 AM |
Eleven Rack vs. Eleven Rack to another interface | petesteen | Eleven Rack | 1 | 02-05-2012 02:53 PM |
Eleven Rack + Another interface? | Kaigne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-01-2009 06:49 PM |
